Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
Thread: FCP X output best for TriCaster
  1. #16
    Jul 2010
    Port Charlotte, FL
    10
    will look up the procedure
    thanks
  2. #17
    Jun 2012
    Los Angeles
    66
    I am also trying to install this codec. However, I don't have Compressor and would rather be able to share to the correct codec from into FCPX.
  3. #18
    19,353
    Quote Originally Posted by mtash View Post
    Apart from the need to sidestep Gatekeeper in Mountain Lion systems only (which is being worked on), installation is a snap.
    I agree. It's puzzling that the developers of FCP opted to limit native export options to such a small list. Anything other than a handful of alternatives requires you to own Compressor, and you don't even get access to the settings of the few codecs it does expose without it. For example, you can't use most of Apple's own Quicktime codecs, never mind ours. This seems particularly odd when you notice that even iMovie does not have these limitations ... nor does Avid Media Composer for that matter.
    This all said, if you don't need an alpha, for an XD series TriCaster, you might find that one of the two XDCAM HD options in FCP's Export Media feature work ok (for an SD TriCaster or export, a DV Quickitime file would probably be fine). I haven't tried them, but they are very similar to one of NewTek's own Quicktime formats.
  4. #19
    Jul 2010
    Port Charlotte, FL
    10
    a fix that works...
    IF you have Compressor 3 (old version) installed...
    use Compressor to create Custom Presets for the SpeedHQ codecs
    open {User Folder}>Library>Application Support>Compressor
    Cmd+Click all those you made (SpeedHQ0.settings for example)
    Control+Click and select "Copy # Items"
    find the Settings folder in the same Compressor folder
    open, Control+Click and paste them there
    open FCP X, under preferences, add a destination
    click the Compressor settings
    the codecs should magically appear
    NOW, I haven't done any "sharing" yet...but hopefully this will work
  5. #20
    19,353
    If you want to avoid all the rigamarole, having created the preset(s) in Compressor all you need to do is select "Export Using Compressor Settings" in FCPX's "Share" menu.
  6. #21
    Jun 2012
    Los Angeles
    66
    Steve: I've bought Compressor 4. Now what?
  7. #22
    19,353
    Here you go: forums.newtek.com/showthread.php?131251
  8. #23
    Jul 2010
    Port Charlotte, FL
    10
    I would have gone that way...but I don't have Compressor 4....and the Share option doesn't work with Compressor 3...(being a school, the software purchasing fund is non-existent there...)
  9. #24
    19,353
    Understood - been there.
