Results 1 to 15 of 17
Thread: Instances and Motion Buffers: Broken?
    Washington State, USA
    2,881
    Hi, I'm trying to figure out a post-effect motion blur workflow, but it looks like the motion buffers are seriously screwed up when using instances. Is there a trick to get it to work?
    Here's the Y motion buffer without the instances turned on:
    Here's the Y motion buffer with instances turned on:
    Here's an experiment using DP filter to combine the Y and X buffers into something Reel Smart Motion Blur can use:
    Incidentally, if I just use LW's built-in Vector Blur image filter, the blur is all wrong too and looks like a zoom blur originating in the lower right quadrant of the image.
    Is there a way to fix or work around this?
    MotionVectorsAndInstances.zip
    I fogged it (Case 51998)
    2,881
    Is this a known issue? Can someone confirm it?
    skeptic lertola2's Avatar
    Dec 2008
    New York City
    1,155
    There was one point a year ago when I tried to get something out of lightwave that would work with Reel Smart Motion Blur. Despite a lot of advice from very smart people on this list I was never able to get it to work properly. Even non instanced geometry has the same problem I think. I would love to have someone in the know post a clear explanation of how to get to get motion vectors out of lightwave and into aftereffects with RSMB. It is still a mystery to me.
    2,881
    I got an email back about my bug report and the problem didn't happen on the latest build, so I hope 11.5 is ready before I need to render.
    Here's a video showing my experimental setup for a LW to RSMB Workflow:
    2,881
    double post
    Nov 2005
    malaysia
    281
    Just checking to see if anyone know if this problem has been fixed.
    2,881
    I've been told (on my bug report ticket) that this issue wasn't occurring in newer internal builds, so it should be fixed for LW11.5.
    Nov 2005
    malaysia
    281
    I am still having problems with 11.03.
    I suppose we just have to wait for 11.5...
    Nov 2005
    malaysia
    281
    I have tested in LW 11.5 and there seems to be no difference.
    Can anyone confirm that motion x and motion y buffer still does not work correctly for instances? Does anyone knows any work around?
    LW 11.5 is awesome all around but I really need to figure out this problem (or if there actually is a problem). Really appreciate any feedback.
    Thanks in advance.
    Hey, what's goin on... this is unnerving issue for a long time... Isn't this fixed in LW11.5??
    Red Mage Celshader's Avatar
    Burbank, California
    1,817
    Lightbulb
    Quote Originally Posted by VermilionCat View Post
    Random thoughts:
    • LightWave 11 instances never delivered the correct motion vector information.
    • As far as I know, 11.5 does not fix it.
    • Our compositing pipeline for LW11 Instances at work is no different than the one we used for the volumetric-based DP_Instance, which can show up in almost every render buffer except for Motion Vectors.
    More random thoughts:
    • FiberFX motion vectors were added in 10.1, but lost in 11.0.x.
    • FiberFX motion vectors were restored in 11.5. So that motion vector issue has been fixed.
    Jen's 3D -- LightWave stuff.
    Jen's 2D -- my comic book.
    Python is my smashing board. LightWave is my S.M.A.K.
    Nov 2005
    malaysia
    281
    Hi celshader,
    Thanks for your thoughts. Can you elaborate how you deal with instances in compositing if it cannot use motion vectors. Does this means that you have to fo the motion blur during render? Practically all my scenes have instances...
    Malmö, SWEDEN
    7,774
    Quote Originally Posted by sukardi View Post
    Hi celshader,
    For things lying flat on the ground, you can create a new scenefile that only renders motionvectors, that does not contain any instances at all. We have some shots where there are tons of small things lying on the ground, and doing it this way works fine!
    For larger things, such as trees etc, the only way to get something that kind of works, is to, again, create a new scenefile and place spheres or boxes where the instances are and render thouse with MVectors. In comp, you then use the alpha from the instances as a mask and "project" the motionvectors onto the instances. This doesn't give you exact MBlur, but close enough to make it work.
    This technique was used a couple of times for smoke-effects we did in Max in order to get motionvectors for it.
    Senior Technical Supervisor
    Cinematics Department
    Massive - A Ubisoft Studio
    AMD Ryzen Threadripper 3990X (64 cores/ 128 threads)
    64GB Ram
    Quadro 620
    Windows 10 Pro x64
    Burbank, California
    1,817
    Hi celshader,
    Yes, for those elements that use instances. For example, on a creature show using LightWave 10.1 we had a creature kicking up instanced straw (DP_Instance). The creature was rendered without motion blur, and motion vectors handled the creature's motion blur in comp. The instanced straw was rendered with in-camera motion blur and mixed into the comp.
    Mixing real and post-process motion blur should get a bit easier with LightWave 11.5, since 11.5 offers the ability to render centered motion blur with its "Shutter Open" offset option in the Camera panel. Nuke's Vector Blur could be shifted, but Reel Smart Motion Blur in After Effects was always centered no matter what. Now LightWave's in-camera motion blur can be centered, too.
    Nov 2005
    malaysia
    281
    Thanks a lot Cageman, Celshader.
    You guys really knows your stuff...
