Results 1 to 2 of 2
Thread: Compositing buffer export + selected objects = no antialiasing?
    Oct 2012
    8
    Hello!
    I'm trying to setup some extra buffers for specific objects in my scene.
    I'm adding several "Compositing Buffer Exports" image filters, each with a different name and different object selections. Basically I'm trying to make masks for these objects.
    I noticed that the "diffuse" buffer is creating a white, alpha-like image for the selected objects. Strange naming, but hey, that's what I need so OK, especially since there is no "alpha" buffer in the filter options.
    Now for the problem:
    The filters work... but the resulting images are antialiased only against the background!
    If a separated object is overlapping another objects in the scene (which is not in the render pass, because of the selection) THE RESULT IS A JAGGED EDGE.
    I'm not talking about buffers that are not supposed to be aliased by design like depth or normals... this is a buffer that is PARTLY ANTIALIASED . Now this must be useful for something... (any ideas?) but not what I need.
    Please tell me if this is the expected behavior? and if so, what other buffer/ method can I use to produce simple masks? Without plugins or nodes - yes I know about Janus and Dpont etc. but my bosses insist on using native LW only - for the sake of simplicity.
    Regards,
    Thomas
    Washington State, USA
    2,880
    I'll sometimes use the matte settings for objects if I need to separate them. I'm not sure that's what you're asking about, though. Hmmm, I wonder if you'll still get the jaggies if you set the hidden objects alpha to 'constant black' in the scene editor.
