Results 1 to 8 of 8
Thread: Tool for radially expanding a cone?
    Hello
    Is there a tool which will allow me to radially expand a cone?
    What I mean is - to rotate each point at the cone base - using the cone apex as a pivot - inwards and outwards so as to narrow and widen the cone?
    Interested to know of a Modeler modifier tool, a Layout displacement tool, and most ideally a nodal displacement tool.
    Thanks!
    Cow Orker cagey5's Avatar
    Manchester UK
    3,273
    'H' to size the points with the 'Mode action centre' as 'selection' ?
    Forum Tips
    If English is your first language, you should know it's 'losing' and not 'loosing'!
    I must be missing something obvious. I'm not seeing 'Mode action centre' anywhere. ??
    Manchester UK
    3,273
    Bottom of the screen. It's just a button with ' mode' on it.
    That's in Modeler BTW. Not thought about the layout side of things yet. Too late here for now.
    Forum Tips
    Ah ok. Found the button. Thanks.
    I haven't found the way to apply the tool to get the result I'm after yet though. Am trying to keep the radial edges of the cone a consistent length, and have them radially rotate back from a mostly closed position to a mostly open position.
    Mar 2007
    UK
    688
    Sounds like a radially symmetrical rotate.
    Lightwave doesnt have radial symmetry, or rotational morphs if thats what you are doing.
    Dec 2003
    Portugal
    1,819
    if it is something like this I used twist with a linear falloff...then you can use stretch to expand it...
    Not quite. Thanks for the suggestion though.
    I found a way though. Generated the cone stretching into the z axis. Then in layout, nodal displacement, applied DP Kit Part Move - Stretch (apex being set to the centre of rotation). Stretch in x and y by sin (angle), and in z by cos (angle).
