Results 1 to 2 of 2
Thread: Volumedic ce installation protest, main Ui no Master handler found with volumedic mas
    15,125
    I donīt seem to get anywere with this plugin, been trying to install a couple of times...unfortunatly something in the way.
    last time there was some issues with the UI locking up etc..
    Now testing the CE demoversion...I did install the volumedic in the Lightwave plugin folder though, but in a volumedic folder, in the installation guide it is installed directly under lightwave, not sure
    if that is causing it to no install correctly.
    Anyway, once I try to click the main volumedic UI, it prompts me with an error that it canīt find master handler with the name volumedic master.
    The install location is setup like this on my system
    C:\Program Files\NewTek\LightWave11.0\support\plugins\Volumed ic
    Im testing this on lw 11.03 64 bit maybe it wasnīt released for that, Cant see any seperation for that, only one CE installation exe file.
    See error message image attached.
    This is because the Demo for VoluMedic CE is currenlty 32 Bit only. That is one of the limitations and unfortuantely not mentioned on the website. I apollogize!
    Yes, my Avatar shows a volume rendering...
    VoluMedic Creative Edition only USD 299 !
    www.volumedic.com
Similar Threads
  1. New lower cost volumedic - 299 usd
    By Elmar Moelzer in forum LW - Community
    Last Post: 08-03-2012, 07:37 AM
  2. VoluMedic Light
    By Elmar Moelzer in forum LW - Third Party
    Last Post: 04-15-2010, 01:43 AM
  3. Volumedic experiences, anyone?
    By Hieron in forum LightWave v9.6 Discussions
    Last Post: 12-23-2008, 05:24 PM
  4. VoluMedic - You Gotta See This!
    By Safe Harbor in forum LW - Third Party
    Last Post: 07-24-2007, 03:35 AM
  5. VoluMedic 1.5 officially released
    Last Post: 05-15-2007, 02:56 PM
