Results 1 to 15 of 30
Thread: Gradient banding problem
    Oct 2008
    UK
    13
    Hi all,
    I have just returned to lightwave use after several years off.
    I'm suffering from banding in gradients in my. I have quite an old duel xeon system running 32 bit XP pro, a Nvidia quadro 980xl graphics card, I used to use an NEC crt monitor on this system and the renders displyed fine without banding. but now I'm using a pair of dell 2007wfp ultrasharp monitors, I have no idea if this makes a difference.
    Or is my system just out of date?
    Also getting banding in gradients in ps, so not really unique to LW.
    anyway any help would be much appreciated.
    tks Rich
    8,355
    You are not saying what LW version..
    But do you have Dithering option turned on in Effects > Processing?
    Oct 2008
    UK
    13
    Hi Sensi
    I'm using LW 7.5, but have also installed the demo of v11 and the same problems in both.
    I would have tried the dithering option you suggest but the problem seems to be with gradients in ps as well as lw I think its more and issue with my system than software. Sorry if i have posted an inappropiate thread in lw support forum.
    cheer Rich
    Registered User gravin's Avatar
    Dec 2011
    CNY
    60
    Could be your monitor. It's possible that your new lcd panel just isn't showing gradients as smoothly as your old crt. Do you know what kind of panel type the 2007wfp has, TN or IPS? I've noticed that gradients look great on my IPS lcd screen at my workstation but often look terrible on my laptop screen (banding).
    Sep 2005
    Earth
    3,121
    Have you installed a color profile for your monitors? If so, remove it and set it to srbg.
    Oct 2008
    UK
    13
    Quote Originally Posted by gravin View Post
    Hi I'm not very techy, but a quick google search has releaved the widscreen versions, which I have use an ips panel. these monitors are my home office, I'm currently at work and a graditent in ps looks great. (I dont have lw installed here), so I beggining to think its my system/monitors that could be the problem.
    Oct 2008
    UK
    13
    Quote Originally Posted by 3DGFXStudios View Post
    Hmmm as far as know the monitors are just a default setting, I'll load up srgb tonight when i get home as see if that helps.
    cheers.
    Aug 2010
    Kernow
    2,095
    How about posting a screen grab?
    Oct 2008
    UK
    13
    here you go, the banding is very noticeable in the top 1/3 of this gradient.
    tks for all your help so far.
    ex-LightWave documentation BeeVee's Avatar
    Pessac
    5,264
    It's definitely your monitor because there is absolutely no banding for me in that image - you're not running in 16-bit are you?
    B
    Ben Vost
    LightWave 3D Docs wiki
    AMD Threadripper 1950X, Windows 10 Pro 64-bit, 32GB RAM, nVidia GeForce GTX 1050Ti (4GB and 768 CUDA cores) and GTX 1080 (8GB and 2560 CUDA cores) driver version 456.71, 2x4K 23.5" monitors
    "OH NO!", Joseph Joestar ncr100's Avatar
    San Francisco
    1,104
    Blog Entries
    2
    Looks beautifully smooth to me on my laptop display - terrible on my laptop's external monitor - same computer, different LCD panel hardware.
    -Nick
    audio: Ö ¤ Py
    We-CoŽ Filmz We-Co's Avatar
    Oct 2006
    Minneapolis, MN
    284
    What's your GPU card?
    The Blog ~ The Vimeo
    "Bring'n Your Fantasy To Life!™"
    Oct 2005
    USA
    1,243
    Yep, looks pretty bad on my iPad 3 at high res (2048x1536)
    Super Member Snosrap's Avatar
    Aug 2004
    Ohio, USA
    4,925
    It sounds like you just have a more typical 8bit monitor. 10bit monitors provide smoother gradients because they have more colors to use. 10bit color depth has a 1.07 billion color palette as opposed to an 8bit color depth of 16.7 million colors. 90% of most monitors are 8bit because they are cheaper to manufacture. The higher quality IPS or PVA/MVA type panels are not nessesarily 10bit.
    Super Member JonW's Avatar
    Jul 2007
    Sydney Australia
    2,235
    Quote Originally Posted by Rich1969 View Post
    It would be better to post this as a PNG. Anyway on my Dell 3011 monitor calibrated with a Spyder 3 elite it's ok.
