Results 1 to 13 of 13
Thread: Polygon info panel, select by surface
    Rasterbator Bog's Avatar
    Los Angeles, USA
    4,096
    That would be awesome. I get a lot of Max and Maya models to work with, involving surface names like wire_22319797_smoothing. Texturing them is a pain of click surface, hit i, get the surface name, go to my stats panel and select all polys of that name.
    Being able to add to selection from the Info panel would be super useful.
    Mark Hennessy-Barrett
    www.imaginetix.co.uk
    www.shaxam.com
    ...and then I was on fire.
    7,900
    Selection > Select Entire Surface doesn't work?
    Axes grinder- Dongle #99
    Seattle
    14,733
    I mapped "Select Sel'd Surfs" to ALT+Q. (Real name=Select Entire Surface"). Under Selection/Polys in the menues.
    I renamed it to something I felt was more indicative of its function: IIRC it will work w/multiple surface selections.
    Chose any poly, ALT+Q, all the polys of that Surface selected.
    Praise to Buddha! #resist
    Registered User tyrot's Avatar
    Mar 2006
    in lights
    2,167
    Hey Mark
    I HEAR you brother! A week ago .. i was dealing lots of objs with similar surface names
    I asked a plugin from one of the most coolest plugin writer here ...Chris Peterson.
    and he wrote this
    http://www.chrisepeterson.com/ls/cp_selectsurfname.zip
    Check his website - he has awesome time saver tools that i cannot work without them in any modelling session..
    http://www.chrisepeterson.com/v2/lscripts
    you select ONE polygon and activate plugin .. Viola all the polygons which has the same name selected... I used it every time try it ..
    Thanks Chris again..
    Seattle
    14,733
    Question "Select Entire Surface"?
    Quote Originally Posted by tyrot View Post
    ??? How does this differ from "Select Entire Surface"?
    FWIW, I couldn't find "Select Entire Surface" in any of the dox-- it could be a 3rd party plugin.
    think i expected it to be under the selection drop down,
    so kinda made me miss it, but hey, they included it... \:]
    7,900
    I have it in Selection even in v9.6..
    Seattle
    14,733
    I find it's more reliable, usually, to use the Menu Editor to find things.
    And again, renaming it "Select Selected Surfaces" makes it clear what it's doing. (Although I shortened it to fit on the button.)
    really? couldn't find it... but guess it's there :]
    Seattle
    14,733
    Selection!
    There's all sorts of wacky stuff in the Selection tab, stuff I find very useful and not talked about a lot.
    I mean, "Select Path"?
    "Select Outline" gets good use sometimes, and "Cycle Selection" is very handy indeed. "Cycle Selection" lets you use Parts as Point Sets, and vice versa.
    There's also "Select Entire Part", which allows you to select one poly, then select every other poly in the same Part. Parts do not overlap as selection sets can.
    yep :] good ones :]
    RailPoly and Select Path,
    http://www.youtube.com/watch?v=vVCV1ZXLKzM
    "Select Entire Part" - i use it together with QuickSelect from MentalFish :]
    Cycle Selection? that's new in LW11 i guess?...
    Seattle
    14,733
    Nah, that's been in there at least since 10, maybe longer.
    Edit: Info panel... that's why.
    Now that's it's non-modal, should lessen your motion. Got it, now.
    Why is it you can't add more selected surfaces with the poly stats panel? I can.
    Selecting another surface with the plus in the column and it adds to the selection, here. Doesn't there?
