Page 1 of 3 123 LastLast
Results 1 to 15 of 42
Thread: Speed Modeling Challenge #186 - Punishment.
    Sep 2011
    Arizona
    173
    Rules:
    1. Every week there will be a subject for you to model along with a time limit. You should spend no longer than the allocated time, then post a render of your model. As in most challenges like this, your honesty on modeling times is essential. How you interpret the brief is up to you as long as the final model conforms to what is asked for.
    2. Post a wire-frame and a render at 800x600 or larger.
    3. LightWave must be used for modeling. 3rd party Plug-ins are allowed.
    4. You can enter as many times as you like, posting each in this thread. If you run over the time, the model can still be posted but won't be subject to the judging.
    5. Time spent on texturing, setting up a scene for a render and rendering is not included in the allocated period.
    6. The winner is judged by the challenge starter and the prize is to set up the challenge after next week's .
    This week's topic: Punishment. Any type of device or equipment used for punishment in the past, present or even future (if you have an idea). There is a wide range of things to choose from such as paddle, prison cell, stocks, gallows, and many more. Here's a link to help http://www.localhistories.org/pun.html
    Good luck.
    Time limit: 60 minutes
    Deadline: Wednesday, 29 August 2012, 22:00 G.M.T
    Banned OnlineRender's Avatar
    Dec 2008
    Glasgow , Scotland , UK
    6,375
    I am married * I WIN * no wires required
    Professional amateur Amurrell's Avatar
    Dec 2005
    Lincoln, NE
    1,350
    Quote Originally Posted by OnlineRender View Post
    Aww, you beat me to it.
    --Andrew
    Bono Animo Esto
    Intel Core i5 3570k
    nVidia GTX 970
    8GB DDR3 1333MHz
    Windows 10 Pro 64bit
    Purveyor of Free Models R.Feeney's Avatar
    Feb 2006
    Galway, Ireland
    1,242
    Nobody expects the comfy chair!!
    Super Member Paul_Boland's Avatar
    Nov 2003
    Waterford, Ireland.
    1,103
    Here you go, my first time ever entering. Total time, about 50minutes. Tight confinement is a form of punishment.
ID:	106462   Click image for larger version.
    KnightTrek Productions
    http://www.knighttrek.com
    Super Member Kryslin's Avatar
    Feb 2009
    Prescott, IA
    1,619
    Of course, someone's going to have to go for the joke. I'll see what I can come up with... Actually, I've a couple of ideas, I'll have to see how they work out.
    My Scripts for Lightwave
    South Yorkshire, England
    2,500
    You rang?
    Has to be a modelling record. 3mins total. 10mins texture and light.
    1. Create 48 side disc 2cm width
    2. Select upper and lower poly, bevel, bridge
    3. Select outer row of ring, Connect, select points and pull out
    4. hit tab
    5. Select inner ring, UVmap (for official marks)
    Done.
ID:	106474   Click image for larger version.
    Feb 2009
    Prescott, IA
    1,619
    Looks good.
    I would have gone for an inscription in the ring reading "One Ring to Rule him All..." though.
    Edit : This is the joke I was aiming for (might be offensive, it's crass humor...)
    (Wires Later)
    Sep 2011
    Arizona
    173
    I purposely left this option out of the list of punishments and you guys still went there immediately! Unbelieveable.
    By the way, nice renders. I like those pearl rings.
    2,500
    @bax33: yer, with the purple/pink cover it does give the rings a pearl look.
    Ok, I will promise to do something that actually relates to the topic.
    I didn't like this show as a child. But I watched it because we only got one TV channel. To have to watch this show now would be torture for me. If you don't know about "I Love Lucy", then there is hope that humanity has progressed. Full hour, a bit sloppy on the antenna.
    Feb 2009
    Prescott, IA
    1,619
    As noted earlier, here's the wires for the ring above, to make it an official entry. I'll try to have something more on topic before the deadline wednesday.
    Sep 2011
    Arizona
    173
    Actually, all of these are 'on topic'. When I came up with the topic, the first thing I thought of was marriage, but I didn't want to suggest it. I was just surprised how quickly it came to surface.
    Gribbly's Day Out flakester's Avatar
    Dec 2004
    Birmingham
    1,002
    Continuing along a similar theme - pregnancy tests.
    40 mins modeling, somewhere around the same for the render setup.
    Grand efforts from everyone so far.
ID:	106536   Click image for larger version.
    flakester
    Feb 2006
    Galway, Ireland
    1,242
    A hanging cage or Gibbet. Popular for a time for dealing with pirates and sheep stealers.
    Just about the hour modeling. The render may be far too dark but I just cant tell, my monitor is on its way out and its brightness is becoming rather unreliable.
    Some strange choices on here so far but still good work
ID:	106542   Click image for larger version.
ID:	106543   Click image for larger version.
ID:	106544   Click image for larger version.
