Results 1 to 14 of 14
Thread: Rezizing all surfaces in one fell swoop?
    Registered User ianay's Avatar
    Sep 2004
    glasgow
    159
    I have a building object that I now have to reduce in size by around a half, the problem is that I have a ton of surfaces attributed to this object and Im not too happy with going around resizing every Surface..
    Is there a magic button that resizes the surfaces in 'step' with the object being resized?
    Thanks for all help!
    Using LW10
    Registered User Kuzey's Avatar
    Melbourne
    5,262
    Center Scale...unless I'm missing something?
    Edit: just checked to see if it works with objects in multiple layers, scales them all...like it's one object.
    Kuzey
    Axes grinder- Dongle #99
    Seattle
    14,741
    Kuzey, it's specifically about the Surfaces. If you're talking Center Scale in Modeler, it doesn't affect Surfaces at all.
    If you shrink all the geometry simultaneously in Layout via a parented null, the Surfaces will scale properly (done! maybe), but the whole setup becomes brittle in that you have to use Load From Scene. If you Save Transform the LWOs, the Surfaces (IIRC) are not scaled and next time you load the LWOs they'll be wrong unless you keep track of the scale %, apply it to a Null, and reference that Null in all your Surfaces. Again, this gets brittle and easy to lose.
    Praise to Buddha! #resist
    Super Member Snosrap's Avatar
    Aug 2004
    Ohio, USA
    4,925
    If you UV mapped everything it shouldn't be a problem, just scale the object. Otherwise just size the object in Layout and have the "size" saved with the scene. Why make it hard.
    Sep 2004
    glasgow
    159
    Damn..
    Seems like there is no 'magic button'..
    The Null version worked ok but i'm pretty screwed if and when it comes to editing the resized object..
    (good thing is the object was pretty much completed anyway, just needed to resize in order to fit it into another scene)
    And vast majority of the surfaces are not UV mapped..
    da what? daforum's Avatar
    May 2006
    Bristol, England
    1,689
    If it's surfaced using non-nodal surfacing, have a look at this:
    http://www.lwplugindb.com/Plugin.aspx?id=369685fc
    Dec 2006
    Philadelphia, PA
    5,738
    If they are node textures it might help to watch a video tutorial I did on the subject.
    http://pixelandpoly.com/video013.html
    Hope it helps.
    May 2006
    Bristol, England
    1,689
    Ha! You beat me to it JeffrySG.
    I was just about to add a link to your video tutorial too!
    Seattle
    14,741
    Isn't there a node that emulates the entire Layer system? Could one use that to Scale?
    I think I'm thinking of the 'Standard' node. -hmmph, no Scale input....
    (Unless there's ANOTHER magical "turn my existing Layer Surface into a Standard Materials node" button, it's still a tonne of work.)
    Sep 2004
    glasgow
    159
    Unhappy
    Though the magic button had appeared there in the aforementioned plugin..
    But..
    Just could not get it to work.. Removed all the nodal surfaces and it still wouldn't work..
    Maybe this magic button will appear in LW12?
    8,104
    You wouldn't have problems if you would use UV mapping since beginning - hint for the next projects.
    So you're saying don't ever use procedurals.
    Eric
    8,104
    Move geometry (in Modeler) - procedural (traditional layered..) screwed. Rescale geometry - procedural screwed. Rotate geometry - procedural screwed...
    There are ways (nodal ways..) to use procedural textures with uv mapping. So any modification of vertex positions won't screw up renders.
