Results 1 to 11 of 11
Thread: Luminous surfaces & transparency -??
    Axes grinder- Dongle #99
    Seattle
    14,733
    Question Luminous surfaces & transparency -??
    So, just about to go to bed but I'm playing w/radiosity and luminous surfaces, and it appears that if a Surface has even 1% of transparency, the LW renderer stops treating it like it's luminous at all.
    Is that correct?
    WUWT???
    Praise to Buddha! #resist
    \\ is sparkling // Iain's Avatar
    Jun 2006
    Edinburgh
    4,441
    If you look at real world luminous elements, the item emanating light is almost always opaque (filaments, diodes etc) and the transparent or translucent part just lets the light through. This is usually referred to as efficacy.
    You should approach this the same way in cg i.e. put your emitter behind the transparent/translucent surface.
    portfolio
    The Liver is evil and must be punished!
    I'm not a squirrel! Mitja's Avatar
    Oct 2007
    Italy
    1,431
    Iain is right. To tell the truth I never even tried to make a transparent object luminous, so yours is quite a revelation to me!
    Another good idea is to evaluate the need of the transparent object. Example, interior renders: if you want to simulate the artificial lighting, the glass of the light bulb is useless, you can't see it in the final render. Contrarily, if you want to make a closeup of the light bulb, you will need that glass. A good idea (I almost always do so) is to put the glass in separate layer and make it unseen by radiosity: faster and cleaner renders.
    P o r t f o l i o .............................................. G+ profile
    To be fair any bulb which has a phosphor coating is both transparent and emissive - such as flourescent tubes - which are not completelly opaque. Either way I 'think' what you need to do is enable 'use transparency' in the radiosity prefs. without this setting transparent objects are ignored by radiosity. Converselly though if you have this enabled radiosity won't transmit through transparent objects - so say sky light through windows - unless you have 'directional rays' enabled - which allows mtl in LW - however this is SLOW - so best avoided unless you need the pretty causrics effects it gives ( albeit monochrome). in such cases you need to treat window glass as a special case and make it a seperate object 'unseen by transparency.
    Seattle
    14,733
    Cool
    Quote Originally Posted by Iain View Post
    If you look at real world luminous elements, the item emanating light is almost always opaque (filaments, diodes etc...
    Flame, neon gas. Thus I refute thee.
    Also, big glowing SF holograms, which the camera goes behind while the protagonist addresses the screen.
    Jun 2006
    Edinburgh
    4,441
    I'm not sure you can refute me when you quoted me saying 'almost always'
    But still, ionized neon gas is what produces the light, not the glass tubing and that was my point; for a realistic effect (and of course, all cg is just an effect, even Maxwell-type engines merely simulate reality through mathematics) having your light source behind a transparent or translucent surface is highly convincing.
    portfolio
    Seattle
    14,733
    That's the issue for me here: I'd like for the luminous object to be behind a refracting tube, but the math used seems to make that severely inconvenient.
    Maybe some slight-of-hand with gradients....
    Neither flame nor ionised gas have a surface, so technically you are wrong, in that their surfacing properties would contribute to lighting.. they are not a surface, but a gas or plasma, however there are examples of transparent luminous surfaces regardless
    If you want to create physically convincing conventional light sources though Iain is right, you should ideally place them behind glass, though it's quite possible to make transparent surfaces emissive, as I explained above, anyway.
    7,900
    Is that correct?
    It's bug in VPR.
    But you must remember that full render is paying attention whether Use Transparency is toggled in Render Globals > GI. If it's not toggled on, surface is ignored in GI stage immediately completely.
    You must understand - it doesn't matter what is plugged or set in Luminosity. What matters is sum of all Diffuse + Luminosity + Translucency, called simply Diffuse Shading.
    If you will use Const > Scalar 10.0 and plug it to Diffuse, then it'll almost like plugging to Luminosity or Translucency (from GI point of view).
    Try plugging Const > Scalar 10.0 directly to Diffuse Shading..
Name:	VPR Error 1.png
ID:	106137   Click image for larger version.
Name:	VPR Error 2.png
    Seattle
    14,733
    Quote Originally Posted by Tobian View Post
    But, not Luminous Surfaces, without compositing, right?
    It's bug in VPR.
    It's a bug in VPR that it won't show 'use transparency' objects, yes. Just tested it, works, as I said it would. VPR can only go so far!
    JS: Not sure what you are talking about: Compositing?
ID:	106139   Click image for larger version.
