Thread: Fracture, pieces left behind, deleting?
    Axes grinder- Dongle #99
    Seattle
    14,729
    Question Fracture, pieces left behind, deleting?
    When you use Fracture, and Bullet leaves a couple pieces just floating around in the air, is there a standard methodology on how to track those pieces down and delete them?
    Praise to Buddha! #resist
    Super Member LW_Will's Avatar
    Somewhere, Out there...
    1,188
    Add gravity
    Will Silver
    Animator
    digital TRiP
    "Frak'em all! I USE LIGHTWAVE!"
    Seattle
    14,729
    MORE? I mean, it's already got gravity, that's why all the other pieces move.
    i think that is a bad fracture....
    which happens a lot, havn't had much time to play but
    is it possible to save trans objects as morph....after dynamics
    then in modeller you could select the stragglers and add them to selection set or assign temp material to them...then morph them back to a solid object and weld the point of the affected geo....to some of the existing fracture pieces
    Registered User suzaku's Avatar
    Jul 2009
    egypt
    21
    I have the same problem, but they r not pieces of the fracture, but rather polygons from some parts
    here's the post I made which contains images:
    http://forums.newtek.com/showthread.php?t=129053
