Thread: Cursor scans timeline on saving
    Cow Orker cagey5's Avatar
    Manchester UK
    3,273
    On some scenes, but not all, when I save a scene. The pointer scans the timeline at the point of saving and is non-interuptable until it gets to the end [Sometimes not the last frame just some consistant point on the timeline]
    On simple scenes it is over in a flash, other times it takes an age.
    It never used to do this I'm sure. So what have I messed up and how do I stop it?
    n.b. Trashing configs had no effect.
    Forum Tips
    If English is your first language, you should know it's 'losing' and not 'loosing'!
    7,891
    This must be something that you used in scene. Find difference between scene that doesn't have it, with the one that has it, and you will have the answer.
    Master plugins can do something like this.
    Save scene, remove item, save again, remove another item, save again, remove something else, and so on, so on. When it'll stop doing it, you have it..
    Manchester UK
    3,273
    Thanks. I did actually try that. I removed everything in the scene, one by one except light and camera of course and they don't have any effect applied.
    Scans real quick with nothing in it but still scans. If I then clear scene, then I'm back to no scan.
    [EDIT] Thanks for the tip on Master Plugins. There was one in there called anchor chain or something. Removing that stopped the scan... Now to investigate what that does and why it was there. Thanks again
    Forum Tips
    7,891
    Attach here the simplest scene with this effect, so we can check..
    Nov 2003
    jersey
    5,766
    Its the anchor plugin... lose it.
    RHA Animation Tutorials
    RHR Rigging Tutorials
    RHN Nodal Tutorials
    YT Vids Tuts for all
