Results 1 to 2 of 2
Thread: SpeedEdit2 Audio Offset Problem
    I have a problem where the Audio Clip's Waveform is offset from the Audio coming from the speaker. Its also is cutting off part of the audio. This was working fine before so I think I must of accidently changed one of the parameters.
    Does anyone know which paarameter controls the Audio Offsets of the Clips in the Timeline?
    Tom
    Tomc
    New Orleans, LA
    76
    Be sure you check the "preference" set up and see if there is a "default" offset you have accidentally changed. I personally have mine set to no offset. Many times when SE crashes and you are forced to reboot etc, you need to go back and check your "preferences defaults" again.
    www.VisionTecVideo.com
