Results 1 to 10 of 10
Thread: How to mix MDD
    Los Angeles
    7,136
    How to mix MDD
    Can somebody please show me how to mix .mdd files? Specifically, I need to replace frame 0 of a character .mdd with a T-Pose.
    I have made an .mdd file of the character in T-Pose, and I have that file and the animation .mdd file loaded in the Node Editor but I haven't a clue what to do next. Just to be clear, I need to replace only frame 0 with the T-Pose and then have the rest of the animation be the animation.
    Can anybody help me out? Thanks in advance for any assistance.
    Best,
    Greenlaw
    My solution would be:
    -load 2 objects... the t-posed model and the MDD-animation model
    -100% dissolve MDD animation at frame 0, and 0% dissolve at frame 1+
    -0% dissolve t-posed at frame 0, and 100% dissolve at frame 1+
    Los Angeles
    7,136
    Thanks for the tip.
    What I need has to be a single object though...it's necessary for some dynamics and hair stuff I'm doing here. I thought I had something working by mixing a T-Pose MDD with Motion MDD in a test, but for some reason this isn't working as expected in an actual shot.
    It sounds like now I might be getting MDDs with the T-Pose baked in, so I might have lucked out.
    G.
    7,891
    Final vector = current position + offset (delta)
    So
    final vector 1 = current position + mdd1 delta
    final vector 2 = current position + mdd2 delta
    mixing vector can be done with Tools > Mixer
    final vector = final vector 1 * opacity + final vector 2 * ( 1.0 - opacity )
    but you need just 0 and 1
    so
    delta = mdd1 delta * 1 + mdd2 delta * 0
    delta = mdd1 delta * 0 + mdd2 delta * 1
    will be fine..
    Red Mage Celshader's Avatar
    Burbank, California
    1,817
    Quote Originally Posted by Greenlaw View Post
    Best,
    Greenlaw
    You can thank the brilliant Ken Nign for the following Node Editor hack to mix MDD files.
    1. In the Node Displacement Editor, load the mdd files using the MDD Displacement node.
    2. Add a Gradient node and make keys on this gradient node.
    3. For each of the keys, activate "Show Output" to reveal their color channel inputs on the left side of the Gradient node.
    4. Plug the MDDs into the Color channel inputs on the left side of the Gradient node. The "colors" are now overwritten with MDD data.
    5. Add a Constant Scalar node and plug it into the Input of the Gradient node. Envelope this value to envelope the transition between the MDDs.
    Jen's 3D -- LightWave stuff.
    Jen's 2D -- my comic book.
    Python is my smashing board. LightWave is my S.M.A.K.
    Burbank, California
    1,817
    For a super cheapie hack...
    For a super cheapie hack, plug the MDD into the blue of Vector Scale and envelope the Scale value from 0 to 1 (with Stepped behavior) on frames 0 and 1. Plug the results into the Displacement node.
    That way the MDD is multiplied by 0 at frame 0, and 1 at frame 1-onwards. Anything times 0 equals 0, while anything times 1 equals itself.
    Los Angeles
    7,136
    Thank you very much guys!
    It sounds like I might not get all the new MDDs with the baked in T-Pose as quickly as I'd like to have them (which is immediately) so this info will help get me started until the data starts coming in.
    Ugh...what a stressful days I've been having lately. Thankfully, the friendly help of the LW community is making it more bearable.
    G.
    Nov 2003
    jersey
    5,766
    You can just use a plain ol mixer node and just animate the opacity value.
    RHA Animation Tutorials
    RHR Rigging Tutorials
    RHN Nodal Tutorials
    YT Vids Tuts for all
    Los Angeles
    7,136
    I had a moment of clarity last night and wound up doing exactly that. Felt kinda dumb that I didn't think of it earlier but happy it worked.
    But still thanks!
