Results 1 to 15 of 24
Thread: What is the best way to make & animate a simple candle flame?
    Sep 2011
    Arizona
    173
    Maybe there is no such thing as a 'simple' candle flame, but that is what I'm trying to animate. I am still a noob, but I've tried Hypervoxels over the last couple of days. Sometimes I get close, but the still have the spherical shape and the color and transparency isn't right. Should I model the flame and use displacement? Any suggestions and guidance would be appreciated, thanks.
    Nov 2006
    Burbank, California USA
    4,576
    A basic teardrop shape with a weight map that masks out the displacement would be fine. The tip should displace more than the base.
    Profile piece
    2010 Reel
    'The X's' Reel
    For an easy glow effect, locate the "glow" setting in surface properties, set it to ~50%.
    Then, in Layout, click Windows (upper left corner) >> image processing >> click "enable glow". The settings for that are global and affect all surfaces based on their glow percentage.
    J.D.Lowe ShadowMystic's Avatar
    May 2011
    San Francisco, California
    453
    The Y scale channel could be adjusted with a noise modifer in the graph editor along with displacement. I want to make a candle now. That could be a challenge to do wax and all
    Hastings, New Zealand
    7,731
    Heres an example done pretty much as described. The flame is displaced geometry. The glow in the candle is a gradient in the luminosity channel.
    Attached Files Attached Files
    Super Member Snosrap's Avatar
    Aug 2004
    Ohio, USA
    4,923
    Axes grinder- Dongle #99
    Seattle
    14,732
    Quote Originally Posted by Snosrap View Post
    Damm! Nice job, Snosrap.
    Praise to Buddha! #resist
    Aug 2004
    Ohio, USA
    4,923
    Thanks, I'll try and find the scene and post some details.
    Mar 2011
    Wisconsin
    222
    Thats a great looking candle Snosrap.
    da what? daforum's Avatar
    May 2006
    Bristol, England
    1,678
    Like that a lot. Looks really good Snosrap
    Sep 2011
    Arizona
    173
    Thanks for the suggestions. I've tried some but without success. I had the flame moving but it was jumping off the candle. Funny, but not success. I'll keep plugging away as time permits. I think I need to research some displacement tutorials and such. So much to learn, so little time. Thanks again.
    Profesor Pixel Poo Mr Rid's Avatar
    Oct 2005
    Los Angeles
    2,794
    First, I would videotape a real candle and map it on geometry.
    "O K, so what's the speed of dark?"
    Demo reel 2017
    https://www.youtube.com/watch?v=yOOixvRhcs4
    Aug 2004
    Ohio, USA
    4,923
    I found the scene. I swapped out the candle for a low poly proxy. For some reason my smoke won't render. It renders in VIPER only. It's an old scene so maybe it's not compatible with LW11 or something else I'm missing. Hope this helps.
    Aug 2010
    Kernow
    2,078
    Thanks Snosrap.
    I know it's your scene and everything, but have you tried turning on Hypervoxels to get the smoke?
    Feb 2010
    Kansas City
    1,140
    Thank you.
    "Once one can articulate an important idea into a concise statement, then one can use the statement and not have to have the fear of changing behavior." - Ed Catmull on Pixar creativity
