Results 1 to 15 of 21
Thread: VPR+GI in perspective and camera view
    Super Member Boris Goreta's Avatar
    Zagreb, Croatia
    1,358
    Why is VPR+GI super fast when moving in perspective view and super slow when moving camera in camera view ?
    16,207
    is there really a difference in the render viewports?
    I mean if you move rotate in another viewport set to wireframe, but view it in camera view. do not use the same viewport and try to move and rotate within the scene itself, that surely is slower.
    But perhaps thatīs not it?
    Michael
    Zagreb, Croatia
    1,358
    I don't really understand what are you trying to say.
    I have one active viewport set to perspective with GI activated and I thumble around the scene, the speed is fantastic.
    Then I change this viewport to be a camera viewport and move camera around and VPR updates are really slow.
    I mean it's the same thing really, just looking around the scene but for some reason when looking through camera it is much, much slower.
    7,988
    You need to place perspective viewport to see exactly the same part of scene with the same distance as camera- then this test will have sense..
    Zagreb, Croatia
    1,358
    No I don't, because difference is huuuge no matter what angle. Guys, did you even try this on some scene of yours ?
    oh corks
    Aug 2010
    end of the line
    888
    Maybe the perspective view is a deliberately very simplified version of a camera, and so it's very quick. And maybe when you're using a real camera, because the image has to properly match the final render, the preview has to do much more complex and fuller camera calculations on every frame.
    Zagreb, Croatia
    1,358
    No, both views deliver the same output quality, and the camera is a simple perspective camera.
    16,207
    Quote Originally Posted by Boris Goreta View Post
    I was refering to that I do not know if you try to move the camera around in directly in the camera viewport where you have vpr on, or if you move the camera around in another viewport where you have it set to wireframe or opengl shadig, that is a huge difference.
    Zagreb, Croatia
    1,358
    No, I just use 1 viewport with active VPR to move.
    16,207
    Ehh..this is confusin, you mean you are using the viewport with vpr active to navigate in, and not another viewport?
    That is not recomended, no wonder it will be slow.
    Michael
    Zagreb, Croatia
    1,358
    Prometheus, you are not making any sense. Why is this not recommended ?
    16,207
    It makes sense, after trial and error, moving items in a seperate non vpr activated viewport is faster than trying to do it in the current viewport with VPR on, thatīs my experience at least, and I suspect that the VPR
    renders staggers because of trying to navigate within the active vpr viewport.
    Edit...that doesnīt say Im completly wrong regarding your problems.
    Michael
    Zagreb, Croatia
    1,358
    Moving camera in another viewport has no effect on VPR rendering speed, it is steel slow compared to perspective viewport.
    Super Member Snosrap's Avatar
    Aug 2004
    Ohio, USA
    4,923
    Yeah, you would think it would be the same. Layout never has been the speedist thing in the world. We need new guts in LW.
    7,988
    When 100% of cpu is used for interactive parallel rendering, no matter what application is used, moving elements in the scene will be with slow down..
    Other apps are often disabling updates while mouse is clicked, and start rendering only after releasing. But I prefer what we have now. Don't want to constantly release mouse button just to update renderer!
