Thread: Aliasing on Depth Buffer
    Newbie Member cgb777's Avatar
    Mar 2004
    St Louis, MO
    88
    When exporting the depth buffer in 11 the image is coming out aliased even though the depth buffer aa is checked in the render globals panel. Am I missing something?
    Hey, I am in STL as well...
    We use ExrTrader for export. But which of the four or five ways are you exporting your depth buffer?
    Perhaps try one of the other ones...
    Mar 2004
    St Louis, MO
    88
    A fellow St. Louisan lightwaver, I didn't think there were any of us, cool!
    Running Lightwave 11.0.1 in the effects panel on the processing tab I'm using the image filter "Compositing Buffer Export" I select depth and save the image. Looks like this panel replaced the Render Buffer View and Render Buffer Export in Lightwave 10 that properly anti-aliased the depth image.
    Attached is the aliasing I'm getting in the depth buffer.
