Thread: Livestream Plugin Crashes
    Apr 2012
    Cleveland, OH
    31
    Have seen similar reports in the forums of Livestream plugin not working reliably. We have brand new 850 Extreme 4b right out of the box.
    After anywhere from 1 to 15 minutes (usually, but sometimes it will go longer) it gives the error: Livestreamprocaster.exe has stopped working.
    I need multibitrate/mobile encoding, which is why I want the plugin. Have tried various settings, all with same results. Really want the 876 kbps (Medium/Mobile) just to work - will be fine for our application (don't need HD, etc.).
    We're going live in 9 days. We begin full-scale testing/live runs Monday. This is for a daily show.
    I'm hoping there may be some possible fix (aside from setting up a separate machine to stream to a standalone procaster setup). One of the reasons we went the tricaster/livestream route was for this to work right out of the box.
    I read somewhere there may be a potential fix in beta? If so, we're willing to give it a shot.
    I've used the LiveStream plug at a multi-hour streaming event without issue. But, if you are worried, you can always do it using a RTMP URL (like you do with other CDN networks).
    Here is info page.
    http://www.livestream.com/userguide/...ith_Livestream
    Apr 2012
    Cleveland, OH
    31
    Can I get multi-bitrate/mobile that way by sending FME stream to Livestream?
    You're having more luck than me. Just crapped out after 19 minutes on a test stream here. I opened a ticket with Livestream. Here's the dump:
    Problem signature:
    Problem Event Name: APPCRASH
    Application Name: LivestreamProcaster.exe
    Application Version: 20.2.52.0
    Application Timestamp: 4f43684c
    Fault Module Name: MSVCR90.dll
    Fault Module Version: 9.0.30729.4940
    Fault Module Timestamp: 4ca2ef57
    Exception Code: c0000005
    Exception Offset: 0002463e
    OS Version: 6.1.7601.2.1.0.256.48
    Locale ID: 1033
    Additional Information 1: 0a9e
    Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
    Additional Information 3: 0a9e
    Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
    Read our privacy statement online:
    http://go.microsoft.com/fwlink/?link...8&clcid=0x0409
    If the online privacy statement is not available, please read our privacy statement offline:
    C:\Windows\system32\en-US\erofflps.txt
    Consultant
    Greater Washington, DC Area
    1,390
    Here is info page.
    Kane, good to see you at NAB.
    Many on the forum would love to hear details about your successful configuration both in the plug-in settings and hardware used.
    Sandy Audio Visual LLC
    NewTek Certification Testing Center
    Twitter @DCTriCaster
    TriCaster: All Models
    Cameras: Sony HDC-P1, X300
    My opinion, uncensored. The blog at www.sandyaudiovisual.com.
