Results 1 to 8 of 8
Thread: IK setting, please explain
    Axes grinder- Dongle #99
    Seattle
    14,739
    Thumbs down IK setting, please explain
    See attached JPEG:
    Could someone explain what this dropdown menu's function is? The settings are:
    Base on First Keyframe
    Base on Most Recent Keyframe
    Base on Current Time
    Base on Frame ...
    The explanation of this dropdown is seemingly missing from the dox.
Name:	Motion panel.jpg
    Praise to Buddha! #resist
    Nov 2003
    jersey
    5,792
    its for denoting where the IK solver looks to find its base/rest state/pose.
    RHA Animation Tutorials
    RHR Rigging Tutorials
    RHN Nodal Tutorials
    YT Vids Tuts for all
    Seattle
    14,739
    Thanks for the info.
    I don't understand the implications, but that's more than the PDFs seemingly had.
    Nov 2003
    jersey
    5,792
    IK uses a base state/pose (vis a vis prebend) to determine how the chain should behave, right... this setting tells the solver which frame to look at to get that pose.
    RHN Nodal Tutorials
    So I suppose itīs useful when you have a model with not bent arms/legs/whatever. Then could you rig a character at frame 0 (in instance) an then pose it with arms,legs... bent in frame 1 and specify the base current time on 1? Should it works this way?
    Vector
    Nov 2003
    jersey
    5,792
    Yes... if for some reason you needed to setup a character with perfectly straight limbs at bind pose, you could key the prebend on another frame and reference that... that's basically the purpose of it, whilst things like current/most recent frame options allow you to alter the IK behviour across the course of an animation by changing FK values on the items in question.
    RHN Nodal Tutorials
    Seattle
    14,739
    Ahhhhh, "prebend"! That makes a lot of sense. Be nice if the manual mentioned it, at all.
    "Bind pose"-- is that a common term of art amongst riggers?
    Thanks, RH!
    RebelHill recommended to me the Thimoty Albee book about character animation and he talks about that issue. Very interesting... a few improvements in setup (joints, same as item motion controllers, etc) since Lw8 so the book could be a bit out of date, but the basics still works
    Vector
