Results 1 to 12 of 12
Thread: DVD authoring and burning software
    Aug 2009
    New Zealand near Turangi
    72
    Ulead DVD Workshop came with my SE 1.5 package. I have little experience authoring or burning dvds. I have noticed that Ulead does not get many accolades in the forum. Can anyone recommend something easier to use and better.
    John Ball
    I still use and love working with it for SD work. It's a tragedy that the company never updated it.
    Registered User donx's Avatar
    Feb 2008
    Vancouver B.C.
    404
    I find Sony DVD Architect to be fairly good to work with once you watch the tutorials.
    Unemployed Jester sandman300's Avatar
    Apr 2004
    Phoenix AZ
    1,005
    Ulead was purchased be Corel, so if anything could be considered an update to workshop, it would be Movie Factory Pro.
    I loved DVD workshop, it could do more than most programs (then) and was a lot less expensive. I took a quick look at the Movie Factory Pro, but by the time it came out I had a much better workflow and I never took the time to see if it measured up to its predecessor. But from what I did see, it didn't.
    For Is and Is-not though with Rule and Line
    And UP-AND-DOWN by Logic I define,
    Of all that one should care to fathom, I
    was never deep in anything but--Wine.
    As I said, I still use DVD Workshop for my SD work and have no desire to switch until I switch over to HD. It certainly was a black day in hell when Corel bought the software.
    Aug 2009
    72
    Thanks you three for the comments. I will stick with ULead at least for my present project. Learning how to use the software is half my struggle. I find the file pathway not easy with ULead but I will eventually come to grips with it.
    John Ball
    I am new here...
    Jan 2007
    Bronx, NY
    88
    I use TMPGEnc Authoring Works 4.0 and I am happy with it. New version 5.0 is available now - you can try it for 14 days (limited functions though...)
    Highly recommend!
    Thanks.
    Aug 2009
    72
    Hi xpycm
    I have read a few good reviews re TMPGenc Authoring Works.... You say limited functions? I don't need much beyond basic authoring, encoding and good burning quality. Does it do the basics well?
    I am new here...
    Jan 2007
    Bronx, NY
    88
    Quote Originally Posted by John Ball View Post
    Hi xpycm
    I meant, limited functions for the trial version... Sorry for the confusion. It has everything you need and more...
    Thanks.
    For what its worth
    TMPGenc Authoring Works - in my opinion is dreadful, it is badly designed and not intuitive. Overpriced too.
    Ulead dvd workshop - can't do wide screen menus.
    Sony Architect is excellent it does everything including bluray.
    The only thing is you have to do is to make pre-encoded mpeg2 to get the correct aspect ratio. I use TMPGenc to make these files.
    Good luck!
    raymond
    Feb 2008
    Vancouver B.C.
    404
    I tend to agree on the capacities of Sony Architect. It's a quite flexible and smoothly opperating program. I found it difficult to figure out the logic of where they put, and call, their features, but once I watched the tutorial videos I was able to find what I needed and realize that this program is ready for pro menu building if your imagination takes you there... and it makes it easy to do simple DVD's. It's also very innexpensive to get the stand alone version.
    New Orleans, LA
    76
    I personally use DVDiT Pro from Sonic. I've used it for several years and it is very easy to use for SD and HD. Unfortunately they no longer provide updates/newer versions of the product or sell the older version I already have. I too personally am looking for something similar for the day I will be forced to start using a different DVD author program simply because newer operating systems will stop working with it, since it was developed for XP systems. I'm currently using Windows 7 and it works, but does give me problems once in a while, more than when I was using XP system.
    www.VisionTecVideo.com
