Thread: Instance of Instanced Objects?
    Super Member SteveH's Avatar
    Albuquerque
    480
    Maybe I'm just dense. Well ok...I am definately dense but trying to get an instance of an instanced object. I have a tree object, that has a point cloud that has a leaf object instanced onto it. The point cloud is the child of the tree object. I have points sprayed on a ground plane and I figured if I instanced the tree limbs, than the point cloud - and thus the leaves should be copied right? Nope....
    With HD instance, this absolutely worked this way. I could load from scene my hd instanced tree object and could then hd instance that to my points on my ground surface - and I'd end up with 20 trees with thousands of leaves.
    I can't figure out how to achieve this in LW11.
    And....one more question while I'm at it. If I have 2 leaf objects, and I pick my point cloud and go to instance, and add an object that is leaf 1, set up the scale and rotation etc - surely there's a way to copy all of that and just change the obect to leaf 2 right? Like right click on leaf one object and copy. But no.....tell me what I'm missing here.
    Somewhere between the Darkness and the Light
    Albuquerque
    480
    After rereading my question it seems a little unclear even to me....
    So - let me try a simpler example. Say I have a hand objects and I have a finger object. I take my hand object and instance 5 of the finger objects onto it. Now I load a person who has two arms and I want to instance the hand object - which includes the fingers. How to do it? Tell me how to get the finger - now that just sounds wrong....
    areté adk's Avatar
    Melbourne
    1,505
    As far as I know you can't do this with LW 11's native instances - yet.
    You can however grab Denis's DP Instancer plugin for 11 as it has the "Include Instances" option
