Results 1 to 12 of 12
Thread: Can Bullet be applied to Instances?
    Registered User Remoc's Avatar
    Feb 2008
    Darwin Australia
    126
    I need an object instanced say 200 times.
    Then bullet applied and they drop onto a bouncy floor.
    So, can Bullet be applied to instances?
    Remoc
    I tried it on my current project but it didn't seem to break apart the object "parts" correctly. I may have just missed something as I didn't have time to mess with it.
    ~~Phil Nolan
    Super Member sublimationman's Avatar
    Mar 2007
    Carlsbad, CA
    517
    I asked this not long ago and the answer was no, it does not work.
    Sep 2005
    Earth
    3,121
    You can bake instances to objects with a python script found in the script/general directory. Select the object that got instanced and run the script. Now your instances will show up as normal object so you can do a save transformed or something like that.
    That's good to know, I was wondering about converting instances to objects recently.
    ~~Phil Nolan
    Jan 2004
    Broken Arrow, Oklahoma
    936
    may not directly relate, but I was able to come up with a technique using bullet to solve the dynamcis on proxy objects and then replaced with instance rendering. You can find a little more here: http://forums.newtek.com/showthread.php?t=126313
    Feb 2008
    Darwin Australia
    126
    Yes I found it Thanks
    The path to the python script is from the top Newtek directory
    \support\plugins\scripts\python\layout\generic\bak e_instance.py
    Thankyou
    Remoc
    Feb 2008
    Darwin Australia
    126
    Instances baked but as individual object
    Ok, I successfully baked the instances. ( cool )
    But I now have hundreds of individual objects.
    This makes it hard to apply Bullet to them all.
    Is there a way I can combine the objects into one object.
    Then I would need to apply bullet ( parts ) to only one.
    Thanks in advance.
    Remoc
    Nov 2003
    Austria
    822
    hm, try to send the objects to modeler and cut and paste all the objects in one layer, then use parts for bullet.
    i did not know about that script, really cool thanks for the tip...
    My Portfolio - http://alexs3d.blogspot.com - Now with Photography
    Nice guys, thanks!
    I guess we could also replace the instaces with a point, then use those in other apps etc .. Very handy for millions of instances.
    Model: MacBook Pro 10.6.4 - 2.66 GHz - 4GB - NVD GF GT 330M
    Render: Win7 64 - Core 2 Quad Q9550 2.83GHz - 8GB
    Sep 2005
    Earth
    3,121
    there's also a script out there that saves all selected objects to one single object. http://www.lwplugindb.com or maybe someone posted it here on the forums.
    Scroll down to S and you'll find some nice save scripts http://www.chrisepeterson.com/v2/lscripts
    I don't think this is the best one in your case but it makes things a lot easier.
    SaveTransformed is a nice script for example. Load all the objects back into modeler and save them a one single object.
    London
    2,338
    LWs View/Layers/Collapse Obj in Modeller will do it too, with a few more options to play with as well.
