Results 1 to 8 of 8
Thread: flocking question
    flocking question
    Hi there, I'm having troubles to make instances to run over an irregular elevation ground. I can only make them to run over a plane.
    Anyone can help me, please. How can I simulate the ground collision to make instance run over it? thanks in advance
    NewTek Developer jameswillmott's Avatar
    Dec 2004
    Gold Coast
    3,171
    For the moment you have to use the Lock to Ground feature and give it a texture. If your ground has been generated with a height map, or a procedural, you can use that texture directly, otherwise you'll have to generate a heightmap from the geometry and texture the ground level with it.
    LightWave3D training, assets, news and discussion at www.liberty3d.com
    My opinions are my own and do not represent the opinions of any other entity, Liberty3D is not officially endorsed by NewTek.
    Thanks four your answer , but I don't know how to make the heightmap from a geometry
    Dec 2004
    Gold Coast
    3,171
    Quote Originally Posted by gabaedu View Post
    You have to shade the geometry so the highest part is shaded white and the lowest black, you can use a simple gradient drawn in an art package for this, and applied as a planar texture on X or Z, autosized to fit the terrain.
    Then do an orthographic render from on top, that image will be the height map you need to get the agents to follow the terrain.
    Quote Originally Posted by jameswillmott View Post
    Thank you very much, I'll give it a try
    Ran into this same problem. Sadly, I don't think this technique works, as to use a texture, you'd need to apply it to some form of object so that it knows the dimensions. Of course there is no drop down for object reference. So, think I'm kinda screwed.
    have you found anything different? Would love to hear it if so...
    Washington State, USA
    2,880
    If your terrain object is 50M by 50M, wouldn't your image map also be 50M by 50m?
    You could go to your terrain object's surface panel and temporarily apply the height map image in one of the channels there (color, diffuse, etc.) and click "automatic sizing". Then just copy the image layer, delete or uncheck it in the surface panel and then paste it in the Ground Texture panel for the Flock Generator.
    I'll give that a try. Thought I think I did. Problem is not that I can't match it. I get no height adjustment at all.
    Illmgive it a try Monday. Thanks.
