Results 1 to 8 of 8
Thread: Surface OBJ Sequence: LightWave 10
    Not to scale BlueApple's Avatar
    Nov 2005
    Los Estados Unidos
    1,026
    I have an obj sequence that needs to be surfaced somehow.
    Previously (prior to LW10) I had used splotchdog’s plugin to surface my sequence, but the plugin doesn’t seem to be designed to work with LW 10. Any alternate methods out there? I read someone suggest to export an MDD, but I can’t find the MD_Scan plugin and don’t know if that would even solve my surfacing dilemma. Is there a way to convert the obj sequence to an lwo sequence and batch surface the lwo files?
    Adam Martin
    my portfolio
    Mac Pro 2x3Ghz Dual-Core Intel | 8 Gb RAM | OS 10.6.8 | ATI Radeon X1900 XT
    8,355
    Load all objects in empty scene. Edit one surface. Then use TrueArt's SpreadSurface from website http://www.trueart.pl
    Or you can use TrueGroup node
    http://www.trueart.pl/?URIType=Direc...-Ins/TrueGroup
    Make group with Storage File, Material output connect to Surface's Material input. Spread such surface to all objects. Save them all.
    Then edit one group, and all objects in sequence will have automatically the same material used.
    But if you want different material in different frames, you should envelope Material Multi Switch/Mixer inside of TrueGroup editor and done.
    Nov 2003
    jersey
    5,792
    If all objects have the same surface name... just load them all into layout at once, and in the surface editor, change the mode to "scene"
    RHA Animation Tutorials
    RHR Rigging Tutorials
    RHN Nodal Tutorials
    YT Vids Tuts for all
    Nov 2005
    Los Estados Unidos
    1,026
    Thanks to both of you for your responses.
    SpreadSurface looks good, but I couldn't get it to work with an obj sequence. TrueGroup may work, but I need to get my boss to part with $30 first.
    I ended up loading all of the obj files into Layout at once and used the method RebelHill suggested. After changing the surfaces, saving all objects, and then reloading the first object in the sequence, everything was good to go.
    Adam Martin
    my portfolio
    obj sequence surfaces and edges definition for outlines
    Quote Originally Posted by BlueApple View Post
    I want to use the surface material and edges definitions (outlines) from object 0 for all other frames / objects....
    Help!
    You should create a new thread for this. You just revived a thread from 2012.
    Dec 2004
    San Juan Island
    4,686
    Who cares about how old the thread is when it is about the same topic? All in one place is better than generating a duplicate thread.
    Jan 2005
    Colorado Springs
    1,875
    Quote Originally Posted by Cyberfish_Fred View Post
    Help!
    You can copy-and-paste Surfaces in the Surface editor. If you bring up the Surface editor (F5), and change the "Edit by" pulldown to be Scene, all the Surfaces in the scene will be listed regardless of which Object they belong to. Select the Surface you want to apply to all of them, right-click and select Copy. Then, select the first Surface in the list, hold down SHIFT and select the last Surface (selecting them all), right-click on any of them and select "Paste". They will all now have the same Surface.
    NOTE HOWEVER, that if you Save any Objects, it will overwrite the on-disk object with the pasted surface!
    Unfortunately, you can't copy-and-paste the Edges panel. However, you can get into Scene Editor (CTRL-F1), select all the Objects using a combination of CTRL-click (to select independent Objects) or SHIFT-click (to select ranges of Objects), then press "p" to bring up the Properties panel. When you set the Edges to your liking, they will have been set on all the selected Objects.
    mTp
