Results 1 to 15 of 26
Thread: Is there a "if else node"?
    Sep 2005
    Earth
    3,121
    Is there a "if else node"? Would be handy I there was
    If not... Can someone make it
    Red Mage Celshader's Avatar
    Burbank, California
    1,817
    Lightbulb Please consider the Logic node (Add Node->Math->Scalar->Logic)
    Quote Originally Posted by 3DGFXStudios View Post
    For the Node Editor, please consider the Logic node (Add Node->Math->Scalar->Logic). There's an example of its use here:
    http://lightwiki.net/wiki/How_to_***...esided_surface
    Scroll down to the "Assigning different indexes of refraction to each side of a doublesided surface" section.
    Jen's 3D -- LightWave stuff.
    Jen's 2D -- my comic book.
    Python is my smashing board. LightWave is my S.M.A.K.
    Sep 2005
    Earth
    3,121
    Oh nice that was what I was looking for. Thanks!
    Sep 2005
    Earth
    3,121
    What I actually need right now is a Logic node with more operations. What I need is an AND + OR option. Like this for example: A Equal to B OR C OR D etc. Can someone make such a node? Would be nice to have the option to dynamically add the amount of options A B C D E F G etc
    Code Muppet evenflcw's Avatar
    Stockholm, Sweden
    2,642
    Obviously you could use several logic nodes but I get that you want to avoid that. So how do you imagine or prefer this node to work? Should it add a new input so there is always one unoccupied available?
    Aug 2010
    Kernow
    2,078
    http://www.lwplugindb.com/Plugin.aspx?id=95ec157b
    AS Math Node has two nodes. Logic1 and Logic2. Don't know what they do as they are 32bit.
    Might be what your after?
    Stuttgart, Germany
    13,613
    I've got one like that... unfortunately it is a part of the (commercial) shaderMeister (in this case designed to ease filtering depending on a variety of criteria, but a generic boolean node is included as well)..
    Cheers,
    Mike
    Sep 2005
    Earth
    3,121
    Here a quick mockup I did. I'm a bit sleepy a the moment so maybe I made stupid mistake. Feel free to tell me if I did , but I think this would be very handy. The logic node is really nice especially in the nodal motion editor.
    Sep 2005
    Earth
    3,121
    Quote Originally Posted by Lightwolf View Post
    Cheers,
    Mike
    Oh Mike! You are a hero again. Does it do something similar to what I made up in Photoshop just yet? Seems like you read my mind even before I did. I'll check it tomorrow
    Stuttgart, Germany
    13,613
    No, a lot simpler. But since you can chain them together...
    It is also meant to be used in conjunction with the filter node, which is essentially an if ... else.
    Cheers,
    Mike
ID:	102536   Click image for larger version.
ID:	102537   Click image for larger version.
    Stockholm, Sweden
    2,642
    Wow, that AS_Math_Nodes has alot of goodies! Thanks for mentioning it.
    His Logic2 node allow two comparisons. So you'd still be one short and need to use a secondary node for the last one.
    Sep 2005
    Earth
    3,121
    Quote Originally Posted by XswampyX View Post
    Unfortunately I don't use a 32bit version of lightwave.
    Sep 2005
    Earth
    3,121
    Hey Mike, your node also only makes one comparison right? What I'd like to do is compare a lot of different value's in one single node. It's a lot easier to see whats going on when it's all happening in one node. I need at least 12 comparisons
    Stuttgart, Germany
    13,613
    Yup... you want more then you can daisy chain them... which also allows you to change the order quickly.
    It would make the user interface a real pain to design as it's quite tricky to dynamically add controls to a XPanels GUI (which is the one that allows for embedding).
    Unless there's a pop-up to select on of the x comparisons and a common area to edit the individual operation.
    Cheers,
    Mike
    Sep 2005
    Earth
    3,121
    Cheers,
    Mike
    It's not really necessary to add the comparisons dynamically, a pop-up will do fine. I just thought of it as a screen space saver. It could work like the DP_Extra buffer nodes do with a pop-up that gives you access to 1-10 11-20 21-31 or something like that.
    Chaining logic nodes in a way that they work like a AND OR really confuses
    me even just with one extra comparison
