Results 1 to 15 of 20
Thread: How do I Render an image for off 90 deg viewing
    Reg. Lightwave abUser MacGregg's Avatar
    Jan 2004
    california
    695
    I want to render an image so correct viewing you would NOT be directly in front of the image, you would need to stand to one side and view from say 45 deg not the typical 90 degrees. So, a picture hanging in a hallway would look in correct perspective before I am standing in front of it. I imagine this would be some Camera setting to change the image plane so it is not parallel to the scene, but it has been a couple years since I have used LW. Can I have different vanishing points in different parts of an image in one render?
    I now have LW 11, any help you can give me on this would be great!
    Thanks!
    MacGregg
    "Belief" is irrelevant... it is not a measure of Truth!
    Boxx 8400SE: Windows 7 x64 Dual Intel CPU5482 [8 Cores, 3200 MHz] 16.0 GB RAM Nvidia GeForce 8800 GTX 768MB
    How about something really simple, rotate your monitor 45 degrees and move the camera till it looks right. (shrug)
    nevermind I understan the problem now... I can think of one way to do it, but it would involve doing it in post, render it at a high enough resolution so you can deform it in post, by stretching one side of the image (like the perspective tool in photoshop) I guess you could make a custom lens for it in Lightwave, but this would be easier, but it does involve more render time.
    One Man Army Andy Meyer's Avatar
    Dec 2009
    Lucern, Switzerland
    1,200
    even easier, rotate your head 45 degrees in other direction and move the camera till it looks right :-)
    you can use a mesh as your camera. look for the different camera types in the manual.
    my website: www.andymeyer.ch
    Supermicro 7047A-T/X9DAi: dual E5-2687 8C/16T @3.1ghz | 64GB Ram | nVidia GTX680-4gb (301.42) | Win7 64 Bit (SP1) |
    display 30"+30"+22" | 13 rendernodes, 54 cores
    Super Member sublimationman's Avatar
    Mar 2007
    Carlsbad, CA
    517
    What about using a large plane that is 100% reflective and black. Set it up where you would have put the camera then point the camera at the plane at a 45d angle. Although the image would be mirrored.
    Washington State, USA
    2,880
    I'm not exactly sure what you're after, but I'm pretty sure the Advanced Camera would be the place to look. You just can't use the camera view VPR or OpenGL to see what the custom lens will show you.
    Oct 2003
    Orlando, FL
    4,146
    Is this something you do in camera? Or is this something better done in post?
    I keep thinking of the text painted on the street. Looks right from your car as you drive up to it but from above it is stretched wildly.
    Jan 2004
    california
    695
    That is exactly what I am talking about Dex! I believe this is a Camera setting to change the angle of the image plane, or film plane, so it is not parallel to the camera lens plane. So it stretches the perspective.
    borkalork BORKALORK! biliousfrog's Avatar
    Dec 2003
    Lowestoft, UK
    2,488
    If you're just trying to remove all perspective then use the orthographic camera or the shift camera (which mimics a tilt-shift lens)
    Quote Originally Posted by MacGregg View Post
    I believe this is a Camera setting to change the angle of the image plane.....
    Look at your signature..
    There isn't a setting to change the angle per se, in the advanced camera there are options to use a mesh to deform the lens, I haven't played much with it that is why I can't recommend it, but doing it in post does work.
    Sep 2005
    Earth
    3,121
    Just stretch it in post. Or if you want to be 100% sure it's right: render your image normally, but it on a plane back in lw or a comp program rotate it and render it again.
    Super Member JonW's Avatar
    Jul 2007
    Sydney Australia
    2,235
    Just render an image & then use that image in a projection camera.
    There is an example here with scene post #8 "Tin.zip"
    http://forums.newtek.com/showthread.php?t=125522
    state of confusion
    6,973
    Here is what I think is the end result being looked for..
    The old baseball or football cards that had a pic from looking at it in 1 direction and another when looked from another direction...tho MacGregg was only looking for the 1 direction.
    These were done by slicing a photo into strips and glueing them at a 45 off center of each strip.
    Then the other pic was done same way but from opposite side.
    It could be done the same way in 3D by UV'ing the strips and applying pic to all the strips and also for the opposite side, so as a charector walks by it changes same way the old cards did.
    How you would make that for YOU to see as you go by monitor is not doable that I can think of.
    Skype...lost_in_3d_space
    Sager
    I7-4800 OC'd to 3.3 GHz
    12G 1600mhz mem
    256 gigs raided SSD drive
    Oct 2003
    Orlando, FL
    4,146
    You would still need a lenticular for viewing.
    Chief of me ch.schrul's Avatar
    Oct 2006
    Bern, Switzerland
    97
    i had to read it twice to (hopefully) understand your question...
    how about this setup?
    chris
    1x i7 3960K ¦ 32GB ¦ 3x 580GTX
    1x dual W5580 ¦ 24GB ¦ 580GTX
    1x QX6850 ¦ 8GB ¦ 2x 8800GTX
    3x i7 2600K ¦ 16GB
