Page 5 of 18 FirstFirst ... 3456715 ... LastLast
Results 61 to 75 of 260
Thread: DP Instancer
  1. #61
    Hamburg
    1,571
    Hi Denis,
    the problem from my video seems to be the bug reported by Tajino, crash when dragging the Instance Number slider, but I hadn't VPR active. I'm waiting for SP1 to see if it's resolved.
  2. #62
    7,898
    That must be something else than Tajino- he had several Windows crash reports- as many as rendering threads in VPR used. If he would go to Render Globals and pick up Threads 1, there would be just one Windows crash report.
    You have just one, right?
  3. #63
    Hamburg
    1,571
    Yes, just one. And you're probably right, it's not always the increasing of instance numbers. Here are the steps to reproduce:
    - go to Modeler Tools, make a ground object and a cube
    - select ground object, apply DP Instancer and open it's properties
    - add the cube to the reference list
    - change the Instance Position from Points to Surface, drag Instance Number slider -> crash
    - or first drag Instance Number slider and then change Instance Position from Points to Surface -> crash
    Tested with 1.05 64bit on Windows 7.
  4. #64
    May 2006
    France
    4,036
    Quote Originally Posted by dee View Post
    Yes, just one. And you're probably right, it's not always the increasing of instance numbers...
    I can't reproduce, following the same step,
    using new objects created in Layout,
    or loaded object in the scene.
    Switching to another distribution may change
    the real number of instances, since you are
    limited to 4 corner maximum instances with
    Point mode on a quad poly, in this case,
    internally there's the same need to destroy/create
    instances with the LW Instancing,
    probably another potential case than for VPR.
    May be not specific to DP Instancer
    for this kind of issues, I recommend to test
    similar steps with a LW Instancer.
    Denis.
  5. #65
    Hamburg
    1,571
    Quote Originally Posted by dpont View Post
    Denis.
    Just tried the same steps with LW's instancer, works fine.
  6. #66
    7,898
    Then try this:
    - save scene
    - quit Layout
    - restart Layout
    - load scene
    - drag Instance Number slider
    If it will work without crashing, then switching between modes might be essential key.
    if Instancer in Evaluate() is doing
    if( mode == points )
    // destroy instances like they were in points mode since ever
    // making new instances
    else if( mode == surface )
    // destroy instances like they were in surface mode since ever
    and mode changes, code in if() clean ups instances in wrong mode..
    However, if Instancer in Evaluate() is doing
    // destroy instances always the same way..
    if( mode == points ) {
    } else if( mode == surface ) {
    shouldn't crash..
    Just thinking on loud
    dee, it's also to you
    http://forums.newtek.com/showpost.ph...0&postcount=53
    show module and offset which crashed, always while showing Windows crash window.. ! Make screen-shot.
  7. #67
    May 2006
    France
    4,036
    Not for me, but randomly,
    can't do more.
    Denis.
  8. #68
    May 2006
    France
    4,036
    That must be something else than Tajino- he had several Windows crash reports- as many as rendering threads in VPR used. If he would go to Render Globals and pick up Threads 1, there would be just one Windows crash report...
    Testing with native LW Instancer just 'sliding' today
    in Surface Mode, no VPR, Opengl Preview,
    got 3 critical errors with one thread on a single Core,
    could be critical but not stopping the process,
    so another comes, ..and another one, crash.
    Infortunatly, as I said above this is a random issue.
    Denis.
  9. #69
    7,898
    I got it too.
    But it was damn hard job.
    20 minutes of sliding back and forth and just two crashes.
    AppName: layout.exe AppVer: 0.0.0.0 ModName: annex.dll
    ModVer: 0.0.0.0 Offset: 00036312
    LW v11.01 build 2240
    Confirm you and dee have exactly the same module and offset..
    But is it the same issue as with DP Instancer? Compare modules and offsets in both crashes..
  10. #70
    Hamburg
    1,571
    Then try this:
    - save scene
    - quit Layout
    - restart Layout
    - load scene
    Did what you sugested but LW64 crashes when loading the saved scene (see attachement).
    I tried 32bit and there's no crash when doing the same steps nor when loading the scene saved from LW64.
    I'm only getting a simple window stating Layout.exe stopped working (see screenshot) and the option to close the program.
    This I copied from the Event Viewer:
    Name der fehlerhaften Anwendung: Layout.exe, Version: 0.0.0.0, // faulty app name
    Zeitstempel: 0x4f2882f3 // timestamp
    Name des fehlerhaften Moduls: DP_Instancer_x64.p, Version: 0.0.0.0, // faulty module name
    Zeitstempel: 0x4f5a8711
    Ausnahmecode: 0xc0000005 // exeption code
    Fehleroffset: 0x000000000002c5d4 // error offset
    ID des fehlerhaften Prozesses: 0x1048
    Startzeit der fehlerhaften Anwendung: 0x01ccff727639f5b2
    Pfad der fehlerhaften Anwendung: N:\LightWave11.0_64\bin\Layout.exe
    Pfad des fehlerhaften Moduls: N:\LightWave11.0_64\3rd\DP_Instancer_x64.p
    Attached Files Attached Files
  11. #71
    7,898
    Repeat it couple times, if module and offset is always the same, it's for 99% bug in DPI.
    Trashing memory, causing random crashes, would give different module and offset in every crash.
    Maybe some pointer is not cleared in constructor (if Denis is using C++). new operator is never ever clearing memory to 0. So what happens depends on what was in computer memory prior to allocating memory.
    0xc0000005 is illegal access to memory. So memory was freed already, but it's pointer was not cleared also. Or trashed memory by other code (but every time other memory would be trashed). Or constructor that didn't cleared up all class members, and used is value that was in memory (or computer stack, if it's local C++ object on stack)
  12. #72
    Hamburg
    1,571
    I have plenty of error reports in Event Viewer, all with the same module name (DP_Instancer_x64.p) and offset number (0x000000000002c5d4).
  13. #73
    7,898
    Denis must convert offset to DPI module, to line of source code..
  14. #74
    May 2006
    France
    4,036
    I can't debug the win64 version,
    and I don't think that allocation /deallocation of memory
    is different from win32 and win64 version ..
    until the destroy function is safe..
    Denis.
  15. #75
    7,898
    Are you using malloc() or calloc() to allocate memory? malloc() doesn't clear memory, calloc() does.
