Page 3 of 18 FirstFirst 1234513 ... LastLast
Results 31 to 45 of 260
Thread: DP Instancer
  1. #31
    Quote Originally Posted by dpont View Post
    taking your scene, replacing DP Instancer by LW Instancer,
    Polygon Distribution, 200 instances, VPR on,
    tweaking the instance number causes crashes too.
    Denis.
    You are right! It crashes with instance count changes in LW native instance generator too. Looks like it is not a DP Instancer's problem, but an NT's one. I have fogged the bug, hopefully LW11.1 will have it fixed if not sooner.
    Right now just have to be careful not to change instance count when VPR is active.
  2. #32
    May 2006
    France
    4,044
    The refresh/update problem when typing the Instance Number
    has been fixed for win64 too, DP Instancer version 1.01.
    Thanks Marvin,
    Denis.
  3. #33
    please, please, please can we get a mac version asap? this looks like a must have for handling complex instancing setups with LW11.
    cheers
    markus
    3dworks visual computing
    demo reel on vimeo
    instagram
  4. #34
    London
    2,338
    Excuse my ignorance but what does this offer than LW11's instancing?
  5. #35
    May 2006
    France
    4,044
    Quote Originally Posted by raw-m View Post
    This is LW 11 instancing, but a different instancer/generator,
    I think that you should experiment with LW Instancer first
    which may give you all what you need.
    DP Instancer just gives the same distribution modes and
    features than DP Instance, for DPI users who appreciated them before.
    Denis.
  6. #36
    Stuff
    Nov 2006
    Amherst Nova Scotia
    988
    amazing work thank you both
    Andrewstopheles
  7. #37
    San Jose, CA
    6,507
    Yep, really looking forward to trying recursive instancing once a MacUB version is available. Thanks Denis!
    John W.
    LW2015.3UB/2019.1.4 on MacPro(12C/24T/10.13.6),32GB RAM, NV 980ti
  8. #38
    Cow Orker cagey5's Avatar
    Manchester UK
    3,273
    So I get a 100% crash rate with the following simple scenario and not sure why I appear to be the only one getting it.
    In Layout
    Create Cube 0.01 M
    Create Sphere .5 M radius
    Open Sphere properties and add DPinstancer
    Choose cube from scene object list and add it as new reference
    Increase instance number and watch as new instances appear across the sphere points
    Change 'instance position from 'Points' to 'Surface'
    Instanct Critical error
    I've deleted configs and installed latest version at this point with no change.
    Windows 7. 64bit. AMD Athlon 64 X2 Dual Core 4600
    Forum Tips
    If English is your first language, you should know it's 'losing' and not 'loosing'!
  9. #39
    Manchester UK
    3,273
    Just been trying it again, and now it's working as expected.. Strange. I'll keep trying and post if any other strangness crops up.
    Really good to see instances with instances available. Thanks v much Dennis
    Forum Tips
  10. #40
    May 2006
    France
    4,044
    DP Instancer has been updated to version 1.02, both win32 and win64,
    Instances are now correctly rendered with Surface Distribution, "Timing World" coordinates and Photoreal Motion Blur enabled.
    Denis.
  11. #41
    South Yorkshire, England
    2,500
    Hi Denis,
    Thanks for all your help on in the other thread. Here's the final render. 1 plane, 3 instances with different materials and the 'multi switch' nodel set up.
    Is there anyway to offset the rotation of child instanced items? I.e. have all the propellers at different rotations to the base model.
    Ricky.
  12. #42
    May 2006
    France
    4,044
    Quote Originally Posted by Waves of light View Post
    ..Is there anyway to offset the rotation of child instanced items? I.e. have all the propellers at different rotations to the base model...
    By setting the "Speed" and/or "Offset" parameters in the Motion tab,
    to different minimum and maximum values,
    the Reference must be set to "Timing World" coordinates,
    parent and its children will share the same timing.
    Denis.
  13. #43
    Hamburg
    1,571
    Thanks Denis!
    I had some time today and played a bit with the 1.03-64bit version. It's quite crashy. I could reproduce one crash (see attached vid) for now, will continue investigation later...
    Attached Files Attached Files
  14. #44
    May 2006
    France
    4,044
    Quote Originally Posted by dee View Post
    ...I had some time today and played a bit with the 1.03-64bit version. It's quite crashy. I could reproduce one crash (see attached vid) for now, will continue investigation later...
    Can't play your video here, and your description is..?
    content and step to reproduce please.
    Denis.
  15. #45
    Feb 2012
    Fance
    67
    VLC reads the video without problem...
    Tchao
