Page 2 of 18 FirstFirst 123412 ... LastLast
Results 16 to 30 of 260
Thread: DP Instancer
  1. #16
    Nov 2006
    Burbank, California USA
    4,576
    Had to clear my browser cache. All is well now.
    Thanks Denis!
    Profile piece
    2010 Reel
    'The X's' Reel
  2. #17
    Thank you, Denis!
    www.tonikasurinen.fi
    MacBook Pro 13-inch | Intel Core i5 @ 2.7GHz | 8GB RAM | OSX El Capitan
    LightWave 2015.3 | ZBrush 4R7 P3
  3. #18
    I don't have LW11 yet but will have it in a few weeks and will check it out.
  4. #19
    areté adk's Avatar
    Melbourne
    1,505
    Great news, thank you Denis. You ROCK
  5. #20
    Quote Originally Posted by dpont View Post
    As usual for studying and reproducing an issue,
    if it is not obvious, content may help.
    Denis.
    Denis, here is my test scene that exhibits both the refresh problem and Layout crash while VPR is active.
    Test scene : DP_Instancer_Crash.zip
    Screen cap : DP_Instancer_Crash.mp4
    Please try it. Thanks!
  6. #21
    May 2006
    France
    4,044
    Quote Originally Posted by tajino View Post
    Denis, here is my test scene that exhibits both the refresh problem and Layout crash while VPR is active...
    Ok, I have this habit to press 'Tab' instead of 'Enter'..
    so I confirm the update problem,
    this has been fixed in the version 1.01 of DP Instancer, win32 yet,
    I followed the same steps, and more, for the VPR issue,
    but wasn't able to reproduce the crash,
    please test again with this version.
    Denis.
  7. #22
    Denis.
    Looks like the link for 1.01 is still the same as the old one, DP_Instancer_x32.p filesize is exactly the same as 1.0 (267,442 bytes) , so are the readme, no mention of 1.01 in it.
    Please check. Thanks.
  8. #23
    May 2006
    France
    4,044
    Looks like the link for 1.01 is still the same as the old one, DP_Instancer_x32.p filesize is exactly the same as 1.0 (267,442 bytes) , so are the readme, no mention of 1.01 in it...
    I just download it and get the correct 1.01 version,
    with the mention in the readme file.
    Denis.
  9. #24
    Jun 2003
    Osijek, Croatia
    31
    Thanks Denis this is great!
    Can you please implement something like max points check mark as found in native instancer.
  10. #25
    Denis.
    Ok, it's the browser cache. I just tested 1.01, viewport refresh works now, but VPR still crash with value changes.
    see this : DP_Instancer101_Crash.mp4
  11. #26
    May 2006
    France
    4,044
    Ok, it's the browser cache. I just tested 1.01, viewport refresh works now, but VPR still crash with value changes...
    No crashing here ,probably my limited configuration.
    Denis.
  12. #27
    Denis.
    Probably.
    I'll try it on my oldest single core WinXP32 machine and see if it crashes. Will report back.
    Thanks!
  13. #28
    Denis, I have just tested 1.01 on the oldest system I could possibly get hold of, a single core HT 3.4GHz running WinXP32, 2GB RAM, with freshly installed LW11.0.
    The result : Crash exactly the same as my initial tests, with multiple popups of the LW crash reporter. Using the slider to increase/decrease instance number would produce even more popups.
  14. #29
    May 2006
    France
    4,044
    ...The result : Crash exactly the same as my initial tests, with multiple popups of the LW crash reporter. Using the slider to increase/decrease instance number would produce even more popups.
    I got these crashes in VPR while tweaking the instance number,
    but randomly and I'm not able to debug them,
    not sure this is on my side,
    taking your scene, replacing DP Instancer by LW Instancer,
    Polygon Distribution, 200 instances, VPR on,
    tweaking the instance number causes crashes too.
    Denis.
  15. #30
    May 2006
    France
    4,044
    Quote Originally Posted by dmodric View Post
    ...Can you please implement something like max points check mark as found in native instancer..
    DP Instancer has mainly the same behavior than DP Instance,
    the 'real' Instance Number is automatically clamped internally
    to Max Points or Max Polygons if you set a higher Instance Number,
    I try to limit the addition of minor features because
    in case of multi generators tied to a bunch of NULL objects,
    even unused options cost in memory.
    Denis.
