Page 18 of 18 FirstFirst ... 8161718
Results 256 to 260 of 260
Thread: DP Instancer
  1. #256
    Quote Originally Posted by dpont View Post
    In the LW Instancing system (for native or DP Instancer)
    time offset works only with transformation never with displacement including bones,
    so with an uni-mesh character no other way than using several animated skeleton poses or time shifted MDD.
    In the surface node editor of the mesh reference, use the Instancer Info node (DP Kit tab for DP Instancer)
    plug Index/ID as seed in Random node for whatever variation you need in your surface setup,
    color, scalar etc..
    i.e a random scalar in a 0-360 range values can vary color
    in the hue input of the Color Tool node.
    Denis.
    I don't see index/ID anywhere. Where should it be?.
    Sorry for my ignorance. I'm not too familiar with nodes.
    Can you show me a node setup to follow?
  2. #257
    May 2006
    France
    4,049
    Quote Originally Posted by JamesCurtis View Post
    I don't see index/ID anywhere. Where should it be?...
    For DP Instancer, Instancer Info node is in DPKit/Instance Generator/
    Instance Info node for native Generator is in Spot Info/
    For LW2015, a simple setup for varying colors with Instance ID with DP Instancer,
    Instancer_Info_Nodes.zip
    You can have mor control of the color palette by just input the ID in a Gradient node.
    Denis.
  3. #258
    dpont,
    Thanks for your help. I'll try this out on Monday.
    I'll consider a donation to you when I get paid some money on the project.
  4. #259
    Aug 2016
    a place
    1,853
    If you bend the bone02 (the parent) and key, instead of IK
    should inherit!?
    Denis.
    Thanks, I reconfigured things without the bone hierarchy and it worked.
    Now I am having a shot at rendering with Octane as a test due to speed and I am running into an issue with the DPinstances. They render fine in the octane IPR on a single frame but when you render a sequence, they do not animate and stay on the position in the first frame rendered. I think this should work ok, I think it is that DP instance isn't doing a refresh on scene update to the renderer.
    LW instances will work in this regard so there must be something a little different there in how the instances are handled on rendering a sequence.
    I tried with Octane 4 demo, available here : https://render.otoy.com/plugindownlo...Win64_demo.zip
    when testing this, make sure to enable update instances i the octane render target options.
  5. #260
    May 2006
    France
    4,049
    ...when testing this, make sure to enable update instances i the octane render target options.
    Sorry, not possible to support DP Instancer with Octane, no Cuda here.
    Just a note about this, DP Instancer does different update compared to native instancer,
    mainly to avoid useless re-calculation when evaluating mesh etc,
    but you have an option "Full Update" did yo check it?
    Denis.
