Page 1 of 3 123 LastLast
Results 1 to 15 of 40
Thread: Speed Modelling Challenge #158 – Rambo knife.
    Aug 2010
    Kernow
    2,094
    Exclamation Speed Modelling Challenge #158 – Rambo knife.
    Rules:
    1. Every week there will be a subject for you to model along with a time limit. You should spend no longer than the allocated time, then post a render of your model. As in most challenges like this, your honesty on modeling times is essential. How you interpret the brief is up to you as long as the final model conforms to what is asked for.
    2. Post a wire-frame and a render at 800x600 or larger.
    3. LightWave must be used for modeling. 3rd party Plug ins are allowed.
    4. You can enter as many times as you like, posting each in this thread. If you run over the time, the model can still be posted but won't be subject to the judging.
    5. Time spent on texturing, setting up a scene for a render and rendering is not included in the allocated period.
    This week's topic is : Rambo knife! - You know you want to! Is it a murderous weapon or a brilliant bottle opener? Who cares. Lots of different base designs to choose from, or design your own. Some even come with a survival kit in the handle. It's up to you. I will also accept *any* weapon used in the rambo films. http://www.imfdb.org/wiki/Rambo_III
    "You know what you are... what you're made of. War is in your blood. Don't fight it. You didn't kill for your country. You killed for yourself.. "
    Time Limit - 60 minutes.
    Deadline: Wed. 15th February 2012. 22:00 G.M.T
    __________________
    Super Member COBRASoft's Avatar
    Dec 2005
    Oudenburg, BEL
    3,182
    Nice topic . Unfortunately way too busy developing on Android the last month(s). I hope to join the challenges next month when everything should calm down a bit.
    Aug 2010
    Kernow
    2,094
    Look forward to your return CobraSoft.
    Knocked up a quick one. Needs more work on the teeth and I have left room for some string on the handle grip, but unfortunately I ran out of time.
    It's a lot harder than it first seems.
    \\ is sparkling // Iain's Avatar
    Jun 2006
    Edinburgh
    4,441
    Man-I just spent 85 minutes on this and I haven't even got a decent blade so far!
    Back to the drawing board!
    portfolio
    The Liver is evil and must be punished!
    Aug 2010
    Kernow
    2,094
    Heh, I had to have 3 false starts before I found a technique.
    Sep 2011
    Arizona
    173
    Iain is much better than I, so that explains why my first hour I ended up with only a blade without notches and it looks like its rubber. Maybe its another Fisher Price item.
    Registered User speismonqui's Avatar
    Jan 2008
    Panama
    528
    I'm in! how hard can it be?
    I'm out!
    Dell XPS 8930 8-Core i9 9900K - 64GB DDR4 - GeForce GTX 1050 Ti - Windows 10
    MSI Prestige PS63 4-Core i7 8565U - 16GB DDR4 - GeForce GTX 1050 Ti Max-Q - Windows 10
    South Yorkshire, England
    2,500
    Quote Originally Posted by speismonqui View Post
    I'm out!
    Hard... as hard as cold steel!
    Aug 2010
    Kernow
    2,094
    This could be the 1st no entry speed challenge, I will take a poly ball.
    It's not that hard. You can design your own..... Maybe Rambo was having an off day and had to use a pen knife.
    What about the F1 grenade?
    I used the array tool set @ 15 times to get the teeth, then it's just a simple drag around to get your blade.
    Maybe.
    Ok, 60 minutes for modelling and of course I run out of time.
    Plugin Rope Editor Plus used.
    I tried to do little procedural texturing for that thing.
    And first time used some weight map for textures.
    So at least I learn something new.
    @XswampyX - Your "quick one" knife model is so good.. damn!
    I am waiting to see others works.
ID:	101649   Click image for larger version.
    www.tonikasurinen.fi
    MacBook Pro 13-inch | Intel Core i5 @ 2.7GHz | 8GB RAM | OSX El Capitan
    LightWave 2015.3 | ZBrush 4R7 P3
    Super Member sublimationman's Avatar
    Mar 2007
    Carlsbad, CA
    517
    How do you guys get the gray scale renders with wires?
    2,500
    There's a plugin called polycoloring:
    http://www.artssphere.com/plugins/polygoncoloring.php
    Aug 2010
    Kernow
    2,094
    ... and this thread.
    http://forums.newtek.com/showthread....lygon+coloring
    Edit to add :- Oh, nice knife Creativetone. Love the texture on the cutting edge..... wish I'd thought of that. Very good!
    Mar 2007
    Carlsbad, CA
    517
    Probably not ready to run with the big dogs but here is a try. 40 minutes modeling and tweaking and another 20 or so on texturing (my weak point).
ID:	101669   Click image for larger version.
ID:	101670   Click image for larger version.
ID:	101671   Click image for larger version.
    Mar 2007
    Carlsbad, CA
    517
    Thanks for the plug-in info
