Thread: Software Change
    Jan 2012
    Pittsburgh, PA
    3
    Software Change
    There needs to be a "Qualifer" on the delete button.
    19,355
    Do you mean "Delete" (if so, which delete feature are you referring to?), or perhaps the "Remove" button on the CS?
    Jan 2012
    Pittsburgh, PA
    3
    Sorry...I meant the remove button on the CS. I think there needs a be a prompt after you hit the button or maybe a double button push or an Alt-Remove. I had the operator press the wrong button 5 times during the show. He thought he was pressing the ADD button. In the heat of the battle sometimes you get buttons mixed up. Its just a thought.
    19,355
    Thanks for clarifying. "Remove" is not really a destructive operation, since you can always 're-constitute' the event, but I get your point.
    Jan 2009
    Chicago
    97
    Quote Originally Posted by VPSTECH View Post
    Good point VPSTECH, mistakes happens, especially under pressure, like forgetting punching back the Play List while in Clip List -- then hitting the Remove button while modifying the playlist will remove the clip from the Clip List. Oooops...
    Today I requested an UNDO/REDO button, which would resolve problems in no time. Check this link: http://forums.newtek.com/showthread....on-in-3Play-UI
