Results 1 to 15 of 29
Thread: Render issues
    Newbie Member eureka's Avatar
    Feb 2007
    Melbourne, Australia
    53
    Blog Entries
    1
    Render issues
    Hi Guys
    When i render out using QT attached is how it comes out!!
    No BG using LW11..mind u it happened using LW10.1 too...
    Any ideas...
    Also when i render out using RGB it does the same thing....
    thanks in advance
Name:	Screen Shot 2012-01-30 at 8.50.08 PM.png
    Sep 2005
    Earth
    3,121
    Probably the alpha. But it remember it's always better to render to a image sequence, like TGA32 of OpenEXR if you want to comp it later....
    Feb 2007
    53
    Blog Entries
    1
    Even my sequences are turning out like that..
    I tried changing the alpha format from "premultiply alpha" to "unpremultiply alpha" ..but no luck there either...any other thoughts..maybe im missing something...
    its giving me the s**ts....
    cheers
    Sep 2005
    Earth
    3,121
    Have you checked the render in after effects with ignore alpha enabled? Do you have some strange image filters applied?
    Feb 2007
    53
    Blog Entries
    1
    Quote Originally Posted by 3DGFXStudios View Post
    I will try that..no image filters..btw it happened when i installed FCP-X..crap program...
    Im going to uninstall& restart and see what happens, if you think of anything else..that would be great...
    cheers
    England
    5,854
    Have you tried turning off any hardware acceleration in QT? I've had major issues with that in the past on my old machine... seems fine in Win7, but on XP machines it was horrid. Worth a go??
    Desk Work:
    Desk Home:
    Feb 2007
    53
    Blog Entries
    1
    Hi there..im using a mac!!
    I wondering would that be the same for QT Mac??
    Feb 2007
    53
    Blog Entries
    1
    Hi Again
    That worked.."ignoring the alpha in AE"
    but why is QT giving me this issue..never an issue B4..
    I would rather just export out using QT personally...
    I know its the wrong thing to do in case of a crash but hey..ive been doing it like that since LW5.5..hehe
    cheers
    Feb 2007
    53
    Blog Entries
    1
    Its definitely an alpha issue in LW...but i cant work out how "not have an alpha.."
    any ideas
    Feb 2007
    53
    Blog Entries
    1
    Attached is how it renders out..no problem...anyone got a fix??
Name:	Screen Shot 2012-01-30 at 10.26.17 PM.png
    Sep 2005
    Earth
    3,121
    If you save in a format without alpha like a 24 bit format you won't get an alpha.
    An other trick is to put an invisible poly in your scene. (unseen by camera and rays etc)
    Yup, having Nothing there only leaves the plane in the alpha.
    A 24 bit format is what you want.
    Feb 2007
    53
    Blog Entries
    1
    Im going to try the invisible poly...
    So in my situation i want to render out in QT, how would i do that???...
    How can i make that a 24 bit??
    cheers
    Nov 2006
    Burbank, California USA
    4,576
    Render to an image sequence first and then compile the frames into a QT int something like After Effects, Premiere, QTPro, etc.
    Choose TGA24 or PNG24 as your image file format in LW. That won't render with an alpha channel.
    Profile piece
    2010 Reel
    'The X's' Reel
    Feb 2007
    53
    Blog Entries
    1
    i will give that a try...but thats so time consuming....
