Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
Thread: Split Screen - 4 Boxes - Help.
  1. #16
    Apr 2008
    Racine
    1,660
    Perhaps those are part of the "Content" download? Maybe a RESTORE took system back to SE software, then AE was installed but without AE Content?? Just guessing. I hadn't seen them before, but I wasn't really looking either
    Jeff
    Jeff Pulera
    TriCasters: Mini with AE, TC1
    Camera: Sony PMW-X70 4K
    PTZ: Newtek NDIHX-PTZ1
  2. #17
    I have tried it and it works perfectly, thank you very much for the contribution, it helped me a lot.
  3. #18
    Jun 2006
    Chicago, IL
    523
    BTW, you mentioned you have AE so you should be able to do a multi box layout using Comps. The cool thing is that you can dynamically move those boxes around in real time, for example, to put the "speaker" full screen from the 2x2 layout by initially saving and then recalling the Comps. I do it all the time, although with just a 2x1 layout. Set it up on a M/E and you can cut or transition to the multi box effect. No need for the fixed arrangement of the Helix effects, good as they were.
    Fritz Golman
