Results 1 to 15 of 18
Thread: Split Screen - 4 Boxes - Help.
    Registered User Eventstream's Avatar
    Dec 2011
    Toronto
    17
    Hi Everyone,
    We have a Tricaster 450, running rev4 of the OS, and we want to split the screen into four independent wide-screen boxes (with no background layer). Each box would need to be selectable between a camera input or DDR. You would essentially be seeing a security camera type setup on screen.
    Does anyone know if this is possible, and how to do it? Any help would be greatly appreciated!
    -Mike
    Bloomington, IN
    1,612
    Use the A over B preset (A, B and Overlay) in a virtual input plus one DSK for the fourth source.
    -Jeff
    My TriCaster Blog
    TriCaster Tally Lights
    19,331
    Yep - or, depending on preference/need, two main DSK overlays + an 'A over B' LiveSet, or even a split screen using two VI's.
    NYC
    3,332
    I use A/B with Overlay on Virtual Input and then add a DSK.
    Here is a starting point for a four corner box effect using V1 @ A/B with DSK2;
    Top Left Box: V1 Overlay = X -88.4, Y -50 and scale 49.5
    Top Right Box: V1 A = X 88.4, Y -50 and scale 49.5
    Bottom Left Box: V1 B = X -88.4, Y 50 and scale 49.5
    Bottom Right Box: DSK2 = X 88.4, Y 50 and scale 49.5
    This is for all 16:9 Session's with a small black cross in the middle.
    This layout follows the 850CS so that it's easy to switch corners of the four box live (top of CS has Virtual Overlay, then A and then B. Utility is under that and left on DSK2). So this is how I get my box layout to be one, two, three and four counting top left to right and then bottom left to right.
    Take care,
    Jose Burgos
    NewTek Certified Trainer
    www.burgosfx.com
    FaceBook
    Twitter @NYTriCaster
    Dec 2011
    Toronto
    17
    Thanks for the help everyone. Jose walked us through his method and we were up and running in no time at all. Works like a charm!
    Sep 2014
    Mobile, Alabama
    2
    I have a Tricaster 860 and am trying to do a simple split screen. Just a two-camera split screen. It used to be the easiest thing in the world to do with old switchers, but I am going out of my mind trying to get the Tricaster to do it.
    I looked at the "help" video from the John Lennon Tour Bus or whatever it is, and I tried to set my M/E bank up like his, but when I hit reset and crop, the positioner joystick has no effect on anything.
    Can someone please help me?
    19,331
    Well, there are lots of ways to do this, but here's an easy one. Open an M/E, and assign the Transitions>Edge>Edge LtoR(H) effect to it. Select the desired two sources on the A and B, and pull the (M/E) T-Bar to taste. Voila....
    Macro Titan JonRaidel's Avatar
    Sep 2009
    Los Angeles, CA
    214
    I build all my box effects/split screens using VSE. it eliminates the errors or inconsistencies. then I build macros to load the box effect into each M/E.
    Gear Used:
    TCXD 8000
    3Play 4800
    VizRT IP 2-Channel
    Panasonic HDX 900 Cameras
    NDI Connect Pro
    Graphic Outfitters ScoreHD
    Graphic Outfitters Scorebridge
    Livetext 3 w/ LT [Scoreboards 2]
    19,331
    Sure, and of course there are default double-box LiveSets.
    Jan 2019
    Mitchellville, MD
    3
    Hello,
    Isn't there a preset quad split templet already in the Tricaster 460? I have used it before and now I can't find where it is? Did NewTek get rid of it?
    Kindly,
    Marshall Johnson
    Sep 2009
    Los Angeles, CA
    214
    there should be a liveset folder named 'Default' or something to that effect with it.
    Gear Used:
    TCXD 8000
    3Play 4800
    VizRT IP 2-Channel
    NDI Connect Pro
    Apr 2008
    Racine
    1,604
    Hi Marshall,
    Often better to start your own NEW thread than resurrect an ancient one referring to different hardware from 2012, confuses things when reading the older posts ;-)
    I've never seen a default quad split. If you have AE on the 460, you should then have "Default 4 Layer" available in the ME and maybe that is what you are recalling? That will give you the 4 layers, but you still need to configure (Scale and Position) the 4 sources yourself to get the desired result.
    Without AE, you can use the 2 Layer set, and then should have 2 Keyers available in same ME with which to apply the 3rd and 4th sources.
    Jeff
    Jeff Pulera
    TriCasters: Mini with AE, TC1
    Camera: Sony PMW-X70 4K
    PTZ: Newtek NDIHX-PTZ1
    Jan 2019
    Mitchellville, MD
    3
    Helix Template
    Attached are two screenshots of the templates I was talking about. I didn't design either of them. They were in my Tricaster already, but I don't know if an update killed them or not.
    Kindly,
    Marshall Johnson
    QUOTE=JPulera;1568389]Hi Marshall,
    Jeff[/QUOTE]
Name:	Screen Shot 2019-04-02 at 1.56.34 PM.png
ID:	144641   Click image for larger version.
Name:	Screen Shot 2019-04-02 at 1.56.06 PM.png
    19,331
    I still see those in the Helix LiveSet folder on my TC1.
    Jan 2019
    Mitchellville, MD
    3
    I only have a double box template in my Tricaster 460 Advanced Edition. I know it was there because of the pictures above, but I don't know what happened to them.
    Kindly,
    Marshall Johnson
