Results 1 to 15 of 21
Thread: Mt first view render
    Absorbs Lightning Whelkn's Avatar
    Los Angeles, CA
    474
    I may have used DEM data ;-) any way. This is my home town MT. MT. Graham Arizona
    Los Angeles, CA
    474
    and by view I mean Vue
    Los Angeles, CA
    474
    Ill probably have an animation posted tonight. Thing takes for ever to render.
    Los Angeles, CA
    474
    http://www.youtube.com/watch?v=5BGu6...1&feature=plcp
    there is the animation-- had to do it at a lower rez and render quality. Vue is really slow---
    Nov 2003
    Austria
    823
    the animation looks good, how long did the render take.
    My Portfolio - http://alexs3d.blogspot.com - Now with Photography
    Los Angeles, CA
    474
    about 15 hrs. on my Dual core Xeon. Time to upgrade.
    15,125
    Quote Originally Posted by Whelkn View Post
    Depends on terrain type and type of cloud model I suspect, avoid spectral 3 clouds if you donīt need them, an extreme clogger that they should rewrite, use spectral 1 clouds, actually thereīs a confusion in spectral naming, the spectral model itself is 3, but they still call the cloud model types 1 and 2, but use model 1 if you can.
    I think you are not using fractal terrains? vue shouldnīt be so slow if your set it up carefully.
    Love your compositing work otherwise, the vue clip isnīt any special thou.
    Yes..upgrade your system, preferably nvida cards for better opengl and pixel shaders, fast cpu etc.
    The dem data itself can be a clogger I suspect, how large is the terrain, what terrain typ did you use, and resolution of it?
    Final render size?
    Michael
    Michael Nicholson zapper1998's Avatar
    spokane washington usa
    4,663
    Blog Entries
    nice..
    animation pretty cool..
    Intel Core i7-980, OC 4.7ghz water cooled.
    Gigabyte x58-UD3R with an Intell SSD 180GIG
    RamCorsair-DDR3-1600-32GIG
    Nvidia Titan Z, x 2 And 1 GTX-1080 by Gigabyte.
    4xEnterprise/WDVelociRaptorŪ300gig
    Los Angeles, CA
    474
    Prometheus I still think its not bad for my first play in Vue never said it was anything special ;-) it was mostly to get the Vue -- Lightwave-- Fusion workflow down for a movie we are working on at work. Camera animation in LW -- object creation and rendering of frames in Vue -- and then loading all objects into Fusion for Multiple Image projections-- it works really well.
    Zapper-- thanks man :-)
    15,125
    Yes indeed, I got that..first time testing around..I can only see that once you get custom with it, we will most like see great stuff from you.
    Your compositing work rocks, so you will have another great tool for matte paintings at your disposal, a little more late nights and you will pick it up real good, Im certain of that.
    What you could try while learning landscape shots and camera movement, that would be to turn of clouds mostly to easier work with faster previews of your animations etc, unless you do not need special cloud shadows in there or something.
    That will speed up your workflow while testing.
    however sometime you would want to fiddle and even get nice clouds in there in full glory from spectral clouds, you should spend time on that too..
    but perhaps doing so on seperate testing passes, just to understand them
    and only use them when needed in the end
    Thatīs just some advice to avoid being annoyed of how slow vue is, spectral atmosphere can be very slow, so be careful of using the spectral 2 cloud layers if possible.
    Michael
    Los Angeles, CA
    474
    Thanks for the tips-- now if I can just find the time to mess around with it more
    15,125
    I will take a deep look at my wallet to see if I can spit something out to order latest version soon.
    the terrain editing tools are looking great with spline editing, and roads context sculpting etc.
    I think they have worked quite hard on terrain tools this version.
    I only wish they could work on the latest spectral 2(3) cloud model since it is soo slow, that is why that model has a default quality setting of minus -1 or something to enhance speed, but at cost of grain in the clouds, for godrays and removal of grain in clouds, you would probably need an atmospheric quality setting above 2 and around 4 or something, but that depends also on render AA settings when switching to final or higher render quality.
    Then they really need to get going on enhancing or simply add a density fractal dedicated for clouds, the defaults are lousy and that is why many artists have renders showcasing a lot of round blobs in the clouds that doesnīt look naturaly, if they had weather or gardner clouds or turbulent noise like in Lightwave, that would have been tweakable to quite good clouds, or if they had something close to Terragens cloud density fractals wich are superior.
    I would pick vue over terragen anyway, UI ease of use, speed comparison to terragen is much better.
    Donīt forget the real world outside and study the environment
    And also get a break from the computer with some fresh air,
    it seems you are having some awesome nature next to your neighbourhood right?
    Michael
    Los Angeles, CA
    474
    yup went out this weekend and found some good reference
    https://www.facebook.com/media/set/?...3273385&type=3
    15,125
    Ahh..canīt see the link, Im no facebook fan, avoiding it as much as I can
    until the swedish government forces me to have one
    picasaweb or flickr perhaps?
    Michael
    Los Angeles, CA
    474
    Well here is a few for you
ID:	105969   Click image for larger version.
ID:	105970   Click image for larger version.
ID:	105971   Click image for larger version.
ID:	105972   Click image for larger version.
