Page 1 of 3 123 LastLast
Results 1 to 15 of 42
Thread: Speed Modelling Challenge #155 – Hats & Headwear
    Registered User ArtGoblin's Avatar
    Jan 2004
    Iceland/Norway
    809
    Exclamation Speed Modelling Challenge #155 – Hats & Headwear
    Speed Modelling Challenge #155 – Hats & Headwear.
    Rules:
    1. Every week there will be a subject for you to model along with a time limit. You should spend no longer than the allocated time, then post a render of your model. As in most challenges like this, your honesty on modeling times is essential. How you interpret the brief is up to you as long as the final model conforms to what is asked for.
    2. Post a wire-frame and a render at 800x600 or larger.
    3. LightWave must be used for modeling. 3rd party Plug ins are allowed.
    4. You can enter as many times as you like, posting each in this thread. If you run over the time, the model can still be posted but won't be subject to the judging.
    5. Time spent on texturing, setting up a scene for a render and rendering is not included in the allocated period.
    This week's topic is : Hats & Headwear
    Time Limit - 60 minutes. Something that makes you look mean, something that makes you just that bit more of a gentelman, something which makes you look cool, something that makes you look utterly insane or stupid, or something with more practical uses like keeping your head warm Bring em' on and I'll take my hat of too ye
    Deadline: Wed. 18th January 2012. 22:00 G.M.T
    Aug 2010
    Kernow
    2,095
    A straw weave hat (it's not mine!).
    South Yorkshire, England
    2,503
    Cool hat.
    I can see how that was created. Could that been done in 60mins with a bit of forward planning? I did a tennis racket once, and I presume the mesh would be similar... just knowing when and where the bends occur.
    Have an idea for this week's comp.
    2D is so Flat! oobievision's Avatar
    Dec 2006
    Boca Raton, Florida, USA
    677
    its like the tutorial for the mic mesh. same technique I think.
    Oobievision
    That good looking? chco2's Avatar
    Mar 2004
    the Netherlands
    628
    Hat
    Sweet XswampyX !
    Once created one of these. Remade it in about 40 mins total.
    wires:
    “It's amazing the way people cling to insults. Or what they think are insults.”
    Mar 2004
    the Netherlands
    628
    At BLR there's the LWCAD 4.0 contest is running. I would have thought some of you guys would have entered by now.
    Most likely there will be around 6 entries in total or so.
    You guys all have LWCad 4 or you don't need/want it? Just curious.
    Ciao!
    2,503
    Quote Originally Posted by chco2 View Post
    Ciao!
    Chco2. I wouldn't be offended. I think it's just because a lot have already got LWCAD. That's all.
    Because the comp is 'what methods would have made this easier to model a building' when a lot of people have already bought the solution, because they needed the solution to better their workflow.
    Aug 2010
    Kernow
    2,095
    Quote Originally Posted by Waves of light View Post
    Cool hat.
    Nope, 15 mins after copious amounts of lager (it's Friday, so it's darts night)
    http://youtu.be/NZIeJnfl4Fg
    I've redone it for you, and recorded it. Hic.
    2,503
    Quote Originally Posted by XswampyX View Post
    Excellent. I've also subscribed to your YouTube channel.
    borkalork BORKALORK! biliousfrog's Avatar
    Dec 2003
    Lowestoft, UK
    2,488
    I was at a loose end today so I thought I'd have a go at my first speed model...
    I was going to model a baseball cap but I couldn't find mine so I modelled another cap I had lying around. I made several attempts at rail-cloning some stitching but eventually gave up. Not counting the stitching attempts it was about 30 minutes in total then I spent a little while playing around in Layout.
    OT, is the AA broken in 10.1? This is the first thing I've rendered in it and I had to ramp up the settings way past what I'd normally use to get rid of jagged edges. I'm hoping 11's new AA stuff improves things otherwise I'm going back to 9.6.
    Attached Files Attached Files
    Mar 2004
    the Netherlands
    628
    AA isn't broken afaik, just changed. Use some adaptive sampling or mimic the old AA by using an oversample of around 0.5, or do both oversampling AND adaptive..
    Quote Originally Posted by biliousfrog View Post
    All look great. Especially like the top hat choc2.
    2,503
    Nice advice and nice hats guys. Love the Indian Headgear!
    Aug 2010
    Kernow
    2,095
    A Greek helmet. About an hour. The texture is from one of Kuzeys free models.
    2,503
    @XswampyX: Wow. Very nice.
