Thread: Crashing on Voiceover
    ScotB
    Mar 2011
    Sylvester
    3
    Using SE2 with onboard audio, with a RealTek driver. Crashes on 2 new Win7pro computers with the same configuration. Works fine on older computers with different configurations.
    Would have submitted the problem but the link was dead.
    Thanks for any help or suggestions.
    Registered User ted's Avatar
    Fresno, CA
    4,216
    Just a thought, but have you updated your SpeedEDIT? I think full support for Win 7 came after SE 2.0. But that's calling on a lot of memory which I won't guarantee is acurate.
    Ted R. Ruiz Sr.
    Ad-Venture Video Productions
    Elite NewTek Dealer
    www.editbay.tv
    TriCasters, Most All Models
    Cameras-Mostly HVX 200's
    Wow, that should never have worked on any version of Windows, but for some reason it always (or usually) had.
    I can only guess that some other fix made the supporting code more correct, causing this to finally show up.
    It is now fixed internally and will be in an update soon.
    Thanks for the report.
    John Perkins
    Software Engineer
    "No, it's my natural color..."
    ScotB
    Mar 2011
    Sylvester
    3
    Programs and Drivers Up To Date
    SE2 is up to date.
    Audio drivers are up to date.
    At this point I will probably start trying audio cards. Any suggestions on a cheap audio card that has a proven track record for working?
    Let me be really clear, it will not work as it stands.
    Well, it might occasionally just due to random chance, but it's not the computers fault when it doesn't.
    I've fixed it here, but give us a bit longer to test all the changes we've made.
    John Perkins
    Software Engineer
    ScotB
    Mar 2011
    Sylvester
    3
    Thanks, I will wait for the next update.
