Results 1 to 8 of 8
Thread: Import Items from scene problem
    Lightwave Muddler... wrightyp100's Avatar
    Oct 2009
    Manchester
    342
    Hi guys. Quick problem. I have used Simple rigger to rig a character and all is well. Until I try an d load another character in. Then everything goes wrong. all the nulls are in place, but the objects go crazy. But If I I use simple rigger itself I can have as many characters as I want.
    I just don't want to have to parent objects and sort out align to path issues Every time I want a new rigged character.
    Any thoughts?
    I am the Keeper Of The Cheese!
    My Youtube Channel! Enjoyhttp://www.youtube.com/user/wrightyp100?feature=mhum
    Also, check out my film Production Website.
    http://www.trifectafilms.co.uk
    Nov 2003
    jersey
    5,771
    most likely simple rigger is creating each character with the same names on all the items, bones, expressions, etc... If so, you wont be able to load more than one character at a time because the names will cross over, and parts will start operating parts on other characters.
    To fix, You'll need to find out how the naming convention is set, and get each character, and ALL its parts individually named.
    RHA Animation Tutorials
    RHR Rigging Tutorials
    RHN Nodal Tutorials
    YT Vids Tuts for all
    Oct 2009
    Manchester
    342
    cheers for the quick reply there. Thing is, I have done this before at work with no issue. Not really sure what's happening. Arg etc...
    Nov 2003
    jersey
    5,771
    Could also be a bug currently in LW, that, when loading multiple rigged/boned items into a single scene, causes all meshes to "use bones from" the same set of bones. Easily fixed, just reassign the correct bone set to the correct mesh.
    RHN Nodal Tutorials
    Oct 2009
    Manchester
    342
    Hmmm, upon further inspection, it seems all the bones have fused on the origin. If that makes sense. They are all emanating from one point. Sigh.
    Nov 2003
    jersey
    5,771
    who knows then... maybe simple rigger aint so simple, lol. I would suspect then that perhaps it uses certain plugins actually ON the rig, and that perhaps these, or their references arent importing correctly.
    Not a lot else i can tell you Im afraid.
    Oh geez... I see its a very old (and seemingly no longer available plugin)... doesnt look like its been updated since somewhere in the V7 cycle. In which case, if you're trying to use it with mroe recent versions of LW, Id venture that you're gonna be SOL, and you'll have to write this fella off as a mostly dead plugin.
    RHN Nodal Tutorials
    Oct 2009
    Manchester
    342
    you can still egt it, but yeah, it is old. Whats annoying me is im in 9.5 at home and 9.6 at work, and at work, I can import multiple versions of the same rig. Frustrating.
    http://www.animationsnippets.com/downloads.html Heres where simple rigger is.
    Oct 2009
    Manchester
    342
    Just in work and tried loading in multiple chars, and it works like a charm. Must be a 9.5 bug. Least thats sorted now. Hurrah.
