Thread: Flickering Renders
    Flickering Renders
    Well, you'll have to forgive me, I am having a huge brain fart on this one. But all my rendered files when rendered in Adobe Premiere are "flickering" I have had this issue before but can't remember for the life of me how to correct it. Can someone give me some help on this ?
    Dale L. Campbell Jr.
    Positive Productions Plus!
    .:: happy LightWaver ::. renderwerx's Avatar
    Aug 2011
    Berlin, Vancouver, Christchurch
    165
    if you import as image sequence uncheck "force alphabetically"
    if that is when you have a flicker every 10th frame or so
    if it is random ... I guess you have a gamma error (that doesn't happen in LightWave but to Mental Ray)
    other than that without more details I don't know at the moment
    Quote Originally Posted by renderwerx View Post
    So this is all in Abode Premiere that theres an issue?
    I don't see the option to uncheck "force alphabetically"? Where is it?
    Aug 2011
    165
    I meant After Effects... sorry....
    But either way ..
    when you import image sequence have a look at the dialog box
    what check boxes are there?
    eg. import image sequence?
    there should be also as in AE a checkbox that says force alphabetically?
    if not try to import as I said in After Effects and see if the problem goes away
    I usually do all in AE and not in Premiere
    hope this will help you
    let me know
    So you use AE and not Premiere for your finals?
    Aug 2011
    165
    mostly, yes
