Page 3 of 3 FirstFirst 123
Results 31 to 38 of 38
Thread: LW-link v0.2: a different kind of 3D blocking workflow
  1. #31
    Super Member vncnt's Avatar
    Amsterdam
    1,779
    LW-link v0.27 posted, incl. manual (PDF).
    - bugfix: in case of "fresh manual link" and "re-link" the modified tapename was not copied to the (protected) eventname field so LW-LINK treated this event as a fresh manual link or re-linked event each time you activated LW-LINK.
    - bugfix: "(re-)render proxy file?" didnīt seem to work after "fresh manual link" and "re-link".
    - bugfix: in case of "re-link" the first time the old link was used instead of the updated link, except when relinking to the original LWS scene file.
    - bugfix: BuildMarkers has been centralized and markers/regions outside the preview range wonīt show up in a new or synced LWS scene file. This is better for large projects with lots of markers/ranges.
    - changed the "SYNC in/out regions/marker" button to "SYNC"
    - added check and adjustment for DataOverlay when using SYNC button.
    - changed _LAYOUT_PATH_ and _SCREAMERNET_PATH_ to enable use of LightWave v11
    Free download of LW-link v0.27 http://members.upc.nl/c.koppes1/LW-link.zip
  2. #32
    Amsterdam
    1,779
    LW-link v0.28 posted, incl. manual (PDF) and demonstration video (Vimeo).
    - new: COMPOSITE - creates or opens a (.comp) Fusion 6.3 composition project file, based on available (rendered) Image Sequences and Event name on the Vegas-timeline.
    - MP3 proxy audio has been replaced by PCM audio to be compliant with Fusion
    - modifications to be prepared for LW11
    - several bugfixes
    Demonstration video #3: http://vimeo.com/34524332
    Free download of LW-link v0.28 http://members.upc.nl/c.koppes1/LW-link.zip
  3. #33
    Barcelona
    1,762
    Splendid job, Vincent!
    Thanks! (If only could I test it properly -and sleep sometimes..!)
    Salut!,
    Allabulle.
  4. #34
    Amsterdam
    1,779
    Quote Originally Posted by allabulle View Post
    Sleep?
    Hmm, maybe thatīs why my eyes feel square.
    Of course you could try the free 30-days trial of Vegas.
  5. #35
    Amsterdam
    1,779
    LW-link v0.29 posted, incl. manual (PDF).
    - new: REASON 6 - can send the proxy *.wav file to Reason 6.0.2 as an audio track or opens a (.reason) Reason 6.0.2 project file, referenced in the TapeName field of the audio event on the Vegas-timeline.
    Now you can quickly access music production (or voice distortion) project files from the Vegas-timeline, making LW-link a more universal 3D blocking tool.
    See text remarks in this page: http://vimeo.com/34524332
    Free download of LW-link v0.29 http://members.upc.nl/c.koppes1/LW-link.zip
  6. #36
    Amsterdam
    1,779
    I can confirm that LW-link is compliant with Vegas Pro 12.
  7. #37
    Senior Constrictor Netvudu's Avatar
    Barcelona, Spain
    928
    Iīm going to test this. I just want you to know youīre my new hero
    3d animation? Hah! Did you take a look through your window?thereīs plenty of it...and pre-rendered!!
  8. #38
    Amsterdam
    1,779
    You almost make me blush.
    Yesterday Iīve solved a bug: "Re-opening a Reason file caused Vegas to wait forever". Iīll check for other issues before publishing the next release.
    Another issue is the Preview AVI that is returned by Layout. There seems to be a slight aspect ratio difference between the original source and this AVI plus I try to find a simple solution to force Layout to render to Rec.709 studioRGB (15-235) color space (or force Vegas Pro to add a event plugin) so it will match the XDCAM-EX source files.
    Also found a behaviour that isnīt exactly a bug but just the way Vegas Pro deals with events: if you cut more than one event from one source file it seems that all these events share the same properties, incl. the tape name field. So you canīt have different LWS files linked to this type of events. Iīm looking for alternative method to link events to external files from Layout(+Screamernet) / SynthEyes / Fusion / Reason.
