Results 1 to 15 of 17
Thread: procedural texture help
    www.digitalcrush.co.uk neilp's Avatar
    Newcastle England
    263
    I am trying to recreate the stained wood effect seat detail from the attached photograph, does anybody have any idea of how to do something similar, I've tried messing with the wood procedural in 9.6 but im no where near! Boo Hoo
    Neil
    nowhere
    241
    i always start texturing in procedural way,(i love the results)but if you want photorealism one texture isn't enough, you ll need more layers in different blending modes in order to break artificial appearance. i find basic and crucial alpha and displacement blending modes (between 2 procedurals like a minimum),also gradients to modulate and isolate components of a same procedural to reenforce areas.i think nodes are more powerful and a big time saver but stacks are also very useful and straight forward.So test a little deforming the basic procedural wood with other procedural(like turbulence) and making subtle changes with procedural alphas.
    Carlos Puebla
    //TD 3d Character Artist.
    ncpuebla (arroba) gmail dot com
    Isn't the problem with procedurals for this partciular case, that they're volumetric textures. So you'll get the seat to appear as if it was cut out of a solid piece of wood (ie. wood rings either on the seat or the back). The real chair is made of flat (sheets of) wood that has been bent, so it might be a better approach to use UV mapping to unwrap the chair and an image based texture?
    Newcastle England
    263
    Agreed Myagi - trying to find an image map of wood grain that size is proving dificult
    Neil
    You could render out a texture from LW, using procedural wood on a flat surface, if you manage to get it looking like you want on that.
    I think there might even be a a plugin (possibly DP Kit) that allows you to make a nodal based image, so you can use procedurals to create an image map, and then apply it through UV mapping. That would save the extra step of first rendering out an image map.
    The LW bonus content dir also has one or two wood textures where using a portion of the texture might work well. Or browse the wood surfaces on preset central (the Table one could be a candidate as a base to work from).
    Cow Orker cagey5's Avatar
    Manchester UK
    3,281
    I agree with the UV route. Have a look at some of the links from the following page. May be somethng useful there.
    http://www.mligg.com/?p=247
    Forum Tips
    If English is your first language, you should know it's 'losing' and not 'loosing'!
    I agree with all here, if you are going for photo real, then you cant beat using real photo textures.
    However, you can get procedural textures to behave without having to use uv's by using a quick morph map.
    I knocked this up real fast, its only one procedural (wood) but could be expanded apoun.
    Hope this helps some.
    Newcastle England
    263
    Trevor that is perfect for what i'm doing - could you upload or email the object to use your set up or embelish.
    Neil
    Neil
    \\ is sparkling // Iain's Avatar
    Jun 2006
    Edinburgh
    4,441
    This approach is fine in principle but like all procedural texture work, it won't hold up to close scrutiny. You'll need a decent texture map for anything other than amateur stuff.
    Let me know if you want me to email you some jpegs.
    portfolio
    The Liver is evil and must be punished!
    Newcastle England
    263
    Iain - texture maps would be fantastic if you don't mind emailing them.
    neil at digitalcrush dot co dot uk.
    many thanks
    Neil
    Sure here you go.
    Basically, make a morph map in this case the chair bent, and change the base so that the geometry is flat. That way when you apply a procedural texture it can be applied on one axis.
    When you apply morph mixer to retain your item shape, LW keeps the texture alignment.
    Attached Files Attached Files
    Dec 2006
    Philadelphia, PA
    5,738
    I'd also suggest looking at http://cgtextures.com/ for some great free photo textures.
    Jun 2006
    Edinburgh
    4,441
    Quote Originally Posted by JeffrySG View Post
    Yeah there's some ideal textures there for what you're after.
    portfolio
    17,323
    If you can find textures..sure go for that.
    Uhmm..I made some procedurals of wood walnut for lockers, I might share that, but donīt know if you could use it and it wouldnīt match what youre after exactly,You would have to modify it.
    Unfortunatly this image is to small to see how it looks like, when I get back to work tomorrow I can post a bigger image and perhaps the procedural itself.
    Thereīs a neat little free program called wood workshop, you might wantīto try out.
    http://www.spiralgraphics.biz/ww_overview.htm
    Thereīs also a free shader from simbiont wich has a wood shader..
    plugin..here
    http://www.darksim.com/html/download_simbiont2.shtml
    Shader files
    http://www.darksim.com/Repository/index.html
    Hereīs direct to wood samples and the shaders of wood
    http://www.darksim.com/Repository/tx_Wood/
    The texture on that chair isnīt that advanced for an absolute need of a true photo texture, if you tweak it good you should be getting good results from procedurals.
    Michael
    Jun 2006
    Edinburgh
    4,441
    I have never understood the use of procedurals in realistic work.
    Photo textures are widely available (and we all have cameras for those elusive buggers,) they are easy to use and adjust and they always look more convincing, in my opinion.
    But hey ho, each to their own.
    portfolio
