Thread: Lights corrupted/confused with each other?
    Question Lights corrupted/confused with each other?
    I made a scene with 3 spotlights in LW 10.1 (Lion). But I can’t move any of the lights: they do show as moved in the editor, but when I Render I see the original placement. And when I exit and re-load, my repositioning of the lights is lost. Changes made to light settings are lost too.
    I can Clone a light, and the new light is saved, but I can’t move it either. In fact, when I move it, and reload, some OTHER light has moved, not the one I really moved. Plus the names of the lights (Light 1, Light, Light 3) seem to get randomly swapped around. In addition, sometimes a spotlight won’t show the cone rays, just a little dot in the middle of the light.
    Saving As a new file didn’t help.
    Do I have do abandon this scene, write down all the coordinates and settings and build it up from scratch, or is there a workaround?
    If I have to start over, is there a way to export just my objects and camera to another scene? (Copy and Paste doesn’t seem to work in Layout.)
    Thanks in advance!
    Morgan
    Now I can’t get anything to work in previously fine 10.1 scenes either: not lights, objects, nor camera. Anything I move/rotate/scale shows just fine in wireframe, but doesn’t render that way. I save and re-open, and all changes are lost despite the new file-modified date. Layout gives no error messages, but is non-functional.
    I’ll try a full re-install, although I’m not sure how to “purge” whatever went wrong.
    EDIT: I uninstalled and re-installed. No help. Even a brand-new created scene doesn’t allow any editing at all. I can create and import things, but can’t move them from their defaults or change their properties. Nothing sticks. I’ll contact support in the morning. Looks like I can forget about this deadline
    EDIT2: It’s just the lights thing, as posted above. Other items failing to move are simply “Auto Key” being turned off (and somehow that change survived the re-install). I never use LW for animation and don’t think about those controls, but I must have clicked that off by accident at some point. The lights taking on each other’s details (and names) is still a mystery, but I can work with a fresh scene and re-do just the lights I think. I’ll sleep when I’m dead
    (Oh, and I found "Load From Scene," to answer my other question above.)
    Morgan
    When you did your reinstall, did you also get rid of all configs first? Configs could be getting corrupted somehow.
    Good question. I used the official uninstaller, which you would hope would truly get rid of everything. (Why have an uninstaller otherwise?) But I know nothing about the actual details. Maybe it doesn’t!
    In any case, now that I know the lights issue is just that one scene (the other stuff was Auto Key) I have rebuilt it. So far so good with the rebuild. I’ll keep an eye open for similar behavior to repeat, though.
    Morgan
