Thread: Interior Lighting.
    Jul 2009
    Hermosillo, Mexico
    139
    Interior Lighting.
    Hello, this is my most recent work, i used for lighting, about 15 IES lights and a area light behind the camera. They were rendered in Lightwave 10 and they have not post produccion work. Thanks for your time and I hope your comments.
    \\ is sparkling // Iain's Avatar
    Jun 2006
    Edinburgh
    4,441
    Looks really good Oscar.
    All I'd suggest is trying to lose the hotspots from the IES at the back and put some reflection blurring on those colums.
    portfolio
    The Liver is evil and must be punished!
    Jul 2009
    Hermosillo, Mexico
    139
    Thanks Iain, i´m making a new renders with more accesories in the showcase and i will fix the hotspots.
    AeroAnimator 4dartist's Avatar
    Chattanooga, TN
    1,069
    The red dress looks like foil or metal to me. It's part bump map and part surfacing issues. Too much spec or something.
    I'd agree with the hotspots. Are you working in 10.1 with a linear workflow? That may help it look way more realistic with the lights and keep you from having to battle hotspots like that because the falloff would be more accurate.
    -basically for the linear workflow, just set all your textures to be sRGB, set the display in the ColorSpace tab to be sRGB, and even your output. It'll make everything look too bright so you'll have to probably start over with all your light settings. Hopefully I told you how to do it right lol. Sometimes I get confused with that linear stuff.
    d powerfull Of lightwave abdelkarim's Avatar
    Nov 2008
    algeria
    758
    Nice stay play with lw renders Good . Kray very fast why u wast ur time ?!!!
    Kray would be ideal. But You should put one Area light on ceiling for overall soft lighting, use linear workflow, a good tone mapping.
    Also, manage your IES power, they seem too strong.
    You should also use realistic colors for light so it looks more convincing.
    http://www.3drender.com/glossary/colortemp.jpg
    Jovian picker has kelvin colors
    For all objects, avoid spec / gloss and use reflection / reflection blur instead. You can even mask it with a textured alpha mask tou have a non even reflection.
    To get realistic results, use also a rule: all materials 80% to 90% diffuse MAXIMUM.
    Use fresnel or fake it with gradient so it's more reflective outside.
    When using reflection, diffuse + reflection should equal 100% max. It means that if you use 50% reflection, you shouldn't use more than 50% diffuse. Light is Photons, they are energy, you can't spread more light than you get that's a rule to follow for realism.
    Use good GI and also Normal Map instead of bump. Quixo is a great software that helps to make awesome Normal maps from pictures.
    I tried to point you most of the things that would help you achieve realism. It took me a while to figure all these things out and the Kray community has been very kind and helpful. So I hope it will help you.
    Even thought Kray doesn't have all the passes I'd love, it calculates reflection blur very very fast! The way it handles FG is also awesome, you can get fast and convincing results.
    555Lab.com
    HP Z800 Win 7 x64
    LW11.0.3 x64
    Bi-Quad Xeon E5530 2.40 GHZ
    16 cores Hyperthreaded
    20GB Ram
    Nvidia Quadro FX 4800 1.5GB / CUDA 192 cores
    Dual screen HP LP2475w
    Super Member Snosrap's Avatar
    Aug 2004
    Ohio, USA
    4,925
    Looks pretty good. There are some speckles in there. Up your AA settings and/or turn on HDR filtering on any HDR's.
