Thread: Modeler or Layout 3DS export error... how to 3ds exprot??
    Feb 2011
    Korea
    46
    I'm useing light wave 9.6
    system win7 64bit!!
    I went to Export 3DS
    but, experiencing an error message..
    Modeler and layout the same phenomenon
    message
    [Information
    3DS Export: Operation Failed - code: 1
    3DS Export : Polygons with 3 vertices only]
    if press Shift + t
    3DS Exprot: Operation Failed - code: 1
    3DS Export: Vertex or Polygon count exceeds maximum (64K)
    Why do errors occur?
    Let me know how to solve please
    Aug 2006
    Eureka, CA
    7,077
    Quote Originally Posted by blueeogus View Post
    system win7 64bit!!
    message
    [Information
    if press Shift + t
    You only need to post once.
    "Polygons with 3 vertices only". They need to be triangles.
    "Vertex or Polygon count exceeds maximum (64K)" Too many polygons for the format.
    shrox www.shrox.com
    Heavy Metal Landing
    Professional amateur Amurrell's Avatar
    Dec 2005
    Lincoln, NE
    1,350
    I would try to export the file as an .obj, and then import that into the app of choice you want to. Widely used format that "generally" works well with others.
    --Andrew
    Bono Animo Esto
    Intel Core i5 3570k
    nVidia GTX 970
    8GB DDR3 1333MHz
    Windows 10 Pro 64bit
