Results 1 to 10 of 10
Thread: Rough surface issue
    Registered User waly's Avatar
    Sep 2007
    Republic of Kosovo
    139
    Rough surface issue
    Hi
    Long time no posts, I was kind of bussy this days sorry.
    I have an issue with the native render-er a part of logo surface looks rough not smooth as its supposed to be, I'm animating a logo for a investor, and everything looked perfectly right until I rendered, I'm sending the images rendered with Native LW render-er and Fprime render in which there is no problem
    Please help to fix it.
    I can provide with more info as settings etc.
    p.s. the rough surface that needs to be fixed is marked with red in native render's pic.
    thanks in advance, waly
ID:	96809   Click image for larger version.
    work work day and night just to see a ray of light.
    CG Generalist akademus's Avatar
    Dubai, UAE
    1,606
    Are you using image or procedural texture. If its a UV, subdivide you model a bit more using Shift+D in Modeler.
    Senior CG Artist, Optix Digital Pictures
    Demo Reel
    Behance
    Web folio
    LinkedIn
    Sep 2007
    Republic of Kosovo
    139
    Quote Originally Posted by akademus View Post
    Thanks akademus as soon as i try i ll get back to you.
    Sep 2007
    Republic of Kosovo
    139
    I did some further subdivision using shft+D in modeler but i get the exact same result.
    need more opinions
    Remember Wade's Avatar
    Cypress Texas
    1,387
    Looks to me like you might have a double poly. Try merging points and then merg polys as it looks to be an overlaping poly. Then maybe triple if need be.
    Shuttle XPCVista 64 bit /Core2Extreme x9650 3.00GHz 8GB GeForce 8800 GTS 512 Cintiq 21UX
    Dell 24" LCD Dell XT2 Tablet /Win 7 32 Bit /Core 2 duo SU9600 1.6 GHz 3GB / Mobil Intel 4500MHD
    Oct 2003
    Orlando, FL
    4,146
    I see jaggies in other places in the render. What is your anti-aliasing set to?
    Sep 2007
    Republic of Kosovo
    139
    @Wade Looks to me like you might have a double poly. Try merging points and then merg polys as it looks to be an overlaping poly. Then maybe triple if need be.
    Thank for the reply wade, Yes i checked the poly's looks perfect no overlaping poly.
    @Dexter2999 I see jaggies in other places in the render. What is your anti-aliasing set to?
    Thanks for the reply Dexter, it is set to 30 below are m prt sc for the settings used.
    Oct 2003
    Orlando, FL
    4,146
    I personally haven't had much success with the Perspective Camera. I see you have the anti aliasing set to 30 and you have photoreal motion blur on, yet I don't see that reflected in the actual render.
    I don't know if Perspective Camera is the issue or not, but I would try Classic or Advanced and see what happens.
    Sep 2007
    Republic of Kosovo
    139
    I noticed that when the camera stands against the logo the jaggies don't appear in that particular spot , and yes the edges still have jaggies for some reason.
    please check out the renders to compare.
    thanks
ID:	96815   Click image for larger version.
    Statistics – 'Poly Stats' look for two point poly's delete, may only show up in 'Edges Stats' as 3 Poly edges same deal delete, at least that's my guess may not be correct but is what it looks like, hope it helps
