Thread: Camera problems
    Nov 2006
    Switzerland
    22
    Camera problems
    i have problems with my camera. I have a scene which contains some objects. Now I have scaled these objects bigger in layout, then saved all objectrs. Next I moved my camera to another location to make a render. Now when I hit F9, the camera defaults back to it's original position, and the render is done from this perspective.
    What am I doing wrong? The same also happens if I move around lights. They also move back to their original position when starting a render. Also saving the scene and objects before the render does not help. This is Lightwave 9.6.1, 64bit.
    Any help is greatly appreciated.
    Nov 2006
    Burbank, California USA
    4,576
    You need to key your items into place after moving them. After moring (rotating or scaling too) hit the Enter or Return key to bring up the keyframe window.
    Or work with Auto-key on.
    Profile piece
    2010 Reel
    'The X's' Reel
    Nov 2006
    Switzerland
    22
    Thanks a lot, this was it....so simple I feel stupid ;-)!
    Old Dog Learns New Tricks RudySchneider's Avatar
    Jan 2006
    Lincoln, CA
    1,307
    Adding to what nickdigital said, scaling your object(s) in Layout has no effect on their original size in Modeler.
    There are no problems, only opportunities...
