Thread: Problem with UV Mapping
    Sep 2007
    Maryland
    7
    Hey guys so Im having an issue with my UV mapping for my object. Im trying to make a UV map of the texture it has on it, so im goin to make the map then surface bake it but my UV texture keeps getting long lines across it. ill show u a picture. and when I surface bake it, it has long black lines across it. any idea on how to fix this problem?
    Nov 2006
    Burbank, California USA
    4,576
    It looks like you got polys that are shearing across your UV.
    Profile piece
    2010 Reel
    'The X's' Reel
    Sep 2007
    Maryland
    7
    yea i know. im wondering how to fix this
    Nov 2006
    4,576
    Unwelding your polys and then do the cleanup in the UV window by moving your offending points to where they should be.
    Profile piece
    2010 Reel
    'The X's' Reel
    Sep 2007
    Maryland
    7
    how do I unweld my polys?
    Nov 2006
    4,576
    Quote Originally Posted by arcreamer View Post
    If you do a search in your Edit Menu or Edit Keyboard Shortcuts for "unweld" it should tell you where it's located. On my system the keyboard shortcut is Ctrl + U.
    Profile piece
    2010 Reel
    'The X's' Reel
