Page 17 of 17 FirstFirst ... 7151617
Results 241 to 243 of 243
Thread: 1001 ways to use LW and Blender together
  1. #241
    1,824
    Awesome!
    Is this classic lwo, or lwo2018 ?
    Looks really powerful !
    Seems to be able to import Curves ?
    it’s wicked and the maya one is just the same. tested both and work well.
    i’m using lwo2, which is good as
    lwo3 isn’t supported as well in other apps.
  2. #242
    Staffordshire
    7,809
    Just an FYI, it will import a normal LW curve, but if you use LWCAD, the nurb curve from that will crash it, so you either need to convert to polys using the appropriate LWCAD function, or remove them from the file and save a copy for Blender import.
    Other than that, yup, it pulls in the old LWO files pretty well. As with the other older LWO import however, it doesn't handle ngons gracefully every time. If there are too many points, you end up with the edges but no face.
    Too old to die young.
  3. #243
    Thanks, Good info.  
