Page 16 of 17 FirstFirst ... 614151617 LastLast
Results 226 to 240 of 244
Thread: 1001 ways to use LW and Blender together
  1. #226
    15,118
    Why not correct? That's what I would expect to happen, l
    LWO2 opens fine in 2.79 (not in 2.80 because it's removed).
    LWO3 dies not work in any application as far as I know (tested Cinema 4D, Substance Painter, 3D Coat, Vue or Terragen).
    You said it yourself in a way I found contradictory, that it wasnīt Blender devs fault, but the change of the lwo format, so how is it then that blender 2.7.9 imports the lwo2 2015 format..while blender 2.8 doesnīt...isnīt that an issue with the old lwo format not working in blender? and actually something the blender devs screwed up for 2.8
    The new lwo format is one thing, the fact that blender 2.8 no longer imports the older format either while the older 2.79 version does.. is a different matter.
    To quote you"Well the omission of LWO support is not really Blenders fault but more down to NewTek changing the format. "
  2. #227
    15,118
    Ah yes forgot about that, thanks. Is ODCopyPaste easy to use? Might test that later.
    You do not use shortcuts, you need to use buttons in object/ copy and paste from blender, then switch to lightwave and use paste from external, and the same the other way aroun, use od tools buttons copy and paste in modeler, switch window to blender and go to object/paste from external.
    Quite nice if you use ant landscape premade landscapes, and copy and paste to lightwave, and you can paste both in modeler or in layout.
  3. #228
    Ohio
    862
    I'm not at a computer to check...but couldn't any of us take the LWO import addon from 2.79 and copy it to 2.80? Was there such a change that it doesn't work in 2.80?
    ...and 2.80 may have it but not enabled by default.
  4. #229
    Several applications do or did support the LWO format (for example Cinema 4D, Substance Painter, 3D Coat, Vue or Terragen) but none of them updated their import modules for the new LW 2018+ / LWO3 format.
    Modo added LWO3 support in Modo 12. But that's the only app I know of that does.
  5. #230
    Jun 2014
    Right here
    1,535
    Ah that's what you meant. My answer for that is my previous post (which doesn't apply for 2.79 because the Blender devs were maybe not aware of LWO3 then):
    Maybe the reason why they removed LWO(2) support is because users would try to open LWO(3) files and don't know why it's not working. These users might then claim that Blenders import is broken.
  6. #231
    Jun 2014
    Right here
    1,535
    Quote Originally Posted by hrgiger View Post
    Thanks didn't know that. Nice of them and a smart move (imho) and would be good for Blender too as these 3 applications are used together often.
  7. #232
    Jun 2014
    Right here
    1,535
  8. #233
    I mean, it made sense for Modo to add it as people have used lwo as a object file outside of Modo's lxo since the beginning. Probably less sense for it to be on Blender's radar as fewer people are using LW these days. Substance painter also dropped the format.
  9. #234
    Sep 2015
    Sweden
    586
    Lwo2 import was Nice it even converted skelegons, but I can understand why it was removed since it was after all a legacy format. Hopefully the modern lightwave versions Become successful enough for people to go through the trouble of updating their importers/exporters.
  10. #235
    for lwo2 this might work in Blender 2.8
    http://www.ewocprojects.be/lwoexport.html
    for lwo 2018, not so sure.
  11. #236
    World's Tallest Dwarf safetyman's Avatar
    Maryland, USA
    1,343
    The Blender devs made fundamental changes to its code base, so most plugins will have to be updated. I'm not a programmer, but from what I gather it's not too terribly difficult to convert addons from 2.7x to 2.8x, depending on the addon of course.
    On the subject of characters: Have a look at this... https://diffeomorphic.blogspot.com/2...rsion-131.html
    Combined with Daz|Studio, you can import the character models directly into Blender without having to export it to a 3rd format first. Then import Daz morphs, poses, expressions, clothing items etc. without having to go back to D|S.
    I haven't used LW in quite a while, but from Blender you could probably get something to import into LW without a lot of hassle?
  12. #237
    Jan 2013
    NA
    86
    Here is an import lwo addon for blender 2.80
    http://www.neko.ne.jp/~asagi/P2P/Plugins/blender.html
  13. #238
    Cool.
    Rob Depew
    Modeler/Animator/Editor
    Web Portfolio
    My Patreon
    YouTube
  14. #239
    1,848
    Re: Python script that loads Lightwave LWO files with Maya 2015/2018 or Blender 2.8.
    awesome, thanks!
    here is the UI import options translated to english:
  15. #240
    Awesome!
    Is this classic lwo, or lwo2018 ?
    Looks really powerful !
    Seems to be able to import Curves ?
